J. Doyle
- Feb 17, 2008
....or ignored. A lot of folks forget you can just NOT do something because it requires more tool/effort than you want to put in![]()
Thanks for that…. I needed a good chuckle before work todayShort answer is yes.
To consider:
What do you plan to use your knife for? Both of your knives are for cutting. If you cut something hard enough for the lock to fail, which doesn't make sense, then I think you used wrong tool for the job.
Excuse me for my ignorance, did I write something wrong? According to my usage, when you cut something, you apply the force opposite to the closure. So how can you cut something to the point that the lock fail? Other than battoning or breaking the knife itself.Thanks for that…. I needed a good chuckle before work today
Old back lock, like on the Mercator, a 1860s design, still being made, is indeed weaker than most liner locks despite its similarity design to the modern back.As others have said, it depends. I remember seeing an interview with Michael Walker, the inventor of the liner lock, where he talked about making his lock to be stronger than the existing backlocks on the market. His first liner locks, however, were so thick and had so much tension that a detent ball wasn't needed to hold the blade in the closed position. Also, lockbacks have been around for a long time and have changed significantly; the ones he was comparing to were on more traditional knives and didn't have the strength or reduced blade play of the modern ones.
Generally speaking, though, modern lockbacks tend to be stronger. Part of that may be due to the fact that it's very easy to make a crappy liner lock.
"slight side pressure and you disengage the lock while using the knife". Really? What kind of knives are you buying? I wonder if anyone here has ever had that happen to them with a knife engaged in normal use.In my opinion it's not the structural strength of liner locks that make them dangerous. It's the fact that it is right where your fingers go and all it takes is a slight side pressure and you disengage the lock while using the knife.
That’s your useage. Some people use there knives harder because they were made to handle it, usually.Excuse me for my ignorance, did I write something wrong? According to my usage, when you cut something, you apply the force opposite to the closure. So how can you cut something to the point that the lock fail? Other than battoning or breaking the knife itself.
I don’t understand. When gripping a knife in your hand you are pushing in on the liner lock. This tighter you grip, the more you are locking the blade. What could you possibly be using a knife for so that you are pushing out and accidently unlocking the blade? How does that happen?I had a Kershaw do it.
If you are pushing and the blade gets stuck in the material, like stiff plastic, there is a tendency to want to get it free and twisting it does happen, and it is possible to disengage a liner lock. applying sideways force.I don’t understand. When gripping a knife in your hand you are pushing in on the liner lock. This tighter you grip, the more you are locking the blade. What could you possibly be using a knife for so that you are pushing out and accidently unlocking the blade? How does that happen?
If I remember my engineering materials class from college, steel is stronger in tension than it is in compression. That is the reason steel strength is typically reported in tensile strength...
Lock back knife is stronger than liner lock right?..I have liner lock rat 2, and cresent tool D2 liner lock knives but i don't fully trust them thrusting
Where do "compression" locks -- like in the Spyderco Paramilitary 2 -- fall in the hierarchy? Anyone have an opinion or results? I never really tested or thought about it...
