- Aug 13, 2014
Haven't ever had an issue but I've know only one person to have an axis lock issue personally but other than that none. I don't believe in springs being in knives. 90% of my folders are framelocks
A framelock is a type of spring...I don't believe in springs being in knives. 90% of my folders are framelocks
In the case of frame and liner locks the springs are much larger, and I would imagine the time it would take to stress one to the point of breaking as compared to say an omega spring would not be anywhere in the same ballpark. Other components would likely wear out first.A framelock is a type of spring...
And if you don't believe in them, I can prove they are a reality. Do you want me to show you photographic proof that springs in knives exist?
Unfortunately, it doesn't take the failure of a huge framelock lockbar. It only takes the face to deform slightly.In the case of frame and liner locks the springs are much larger, and I would imagine the time it would take to stress one to the point of breaking as compared to say an omega spring would not be anywhere in the same ballpark. Other components would likely wear out first.
http://www.bladeforums.com/threads/the-axis-lock-springs-and-i.1137741/page-4#post-16483048
Seems like multiple types of wire have been used to good affect.
I certainly agree. Just pointing out that it is a different type of failure. I don't buy frame or liner locks for the very reason you mention (well, I do own one framelock currently), and have nothing against Omega springs either. My preference is the compression lock or Triad, which also use springs, but I believe they will last a decent amount of time, and circumvent some of the issues with framelocks and linerlocks to a degree.Unfortunately, it doesn't take the failure of a huge framelock lockbar. It only takes the face to deform slightly.
On a liner lock, any deformation at all will likely cause blade play and a sloppy lock-up, or at least a significantly shortened life span (in the case of it being forced to have a higher lock up degree).
Omega springs can be replaced at home with some small wire. It takes a few minutes, but yu don't have to be without your knife for a few weeks.
Can you do that with a frame lock?
