nosaj750
Larevo Knives
- Aug 28, 2010
I'm sure this has been covered but when you search lock stick you get a lot of results returned.
I've been making flipper/folders now for a few months and have been selling what I've been making so can't complain one bit. But, it seems my lock cutting procedure is lacking consistency sine I get some lockups that don't stick, then I'll get one that does stick. I think I know what the actual cause is but, would like to hear from more experienced makers and their solution to this problem if possible. It seems the lock face on my blade isn't 100% flat on the ones that stick. With a little sanding with a fine grit and use it seems to dissipate but, it would be nice if the extra time to get it just right wasn't necessary.
My current procedure is to file by hand at 8 degrees with the lock face on the frame flat. I have noticed a few higher end knives I've owned that actual angle the lock face on the frame and blade which seems to work great but, haven't tried that method yet.
Thanks for the info and help with this.
