Something else you guys might want to try that I get good results with is clear fingernail polish. It works great, is much cheaper, doesn't require heat or power tools to undo, and doesn't require toxic chemicals to clean off (only acetone). Plus it is colorless, so it doesn't show up around the tips of those screws that go through the handle to the other side like some BM knives (806 comes to mind). I have used this several times from keeping carbeurator mixture screws at a certain setting to keeping knife screws in place. Once you try it, you won't go back to using expensive lock tite. At least I haven't. Granted, I wouldn't use it on a structural application where a permanent application was needed, that is what the red and green is used for. It does work well on knives though.
Mike
