There is no "pivot tension" to speak of with Sebenza's. The opening/closing tension is determined by the tolerances of the bronze washers, blade tang thickness, lockbar tension/detent ball, and most importantly, the blade bushing
No loctite from the factory. If you have a problem with the way it is I would contact CRK and let them deal with it.
With all due respect, bigmark408, that's not right.
The Sebenza was designed for ease of disassembly, and blue or red Loc-Tite has no place anywhere on the Seb. The pivot screw, as well as all screws on the Seb, should be tightened down to the extent that you hear a "pop" when you release them to disassemble. The screws/threaded pins are made of a relatively soft 303 stainless, which galls together purposefully to eliminate the need for Loc-Tite. The pivot is absolutely not adjustable the way a Benchmade, for instance, is.
Oiling all moving parts in the Seb is the place to start to free-up the action, at both the pivot point, and oiling the ceramic ball detent on the lockbar that contacts the blade. If this, along with a few days of opening/closing do not free up the action, then you can do one of two things:
1. Send it back to CRK for adjustment, or...
2. Get adventurous and try to adjust it yourself by taking it apart and rubbing the washers on a flat surface with a polishing compound such as Flitz to remove a tiny amount of metal from the surface, thus reducing the tolerance and creating more "micro-play," as it were.
I would think oiling and working the action would do the trick before resorting to one of the two options I mention, but then again, I am the same guy who predicted the big Menudo comeback of 2000.
Professor.
iirc, crk advises owners to never use loctite on any part of a sebbie.
if you send a loctited sebbie in for anything, they will drill out the pivot or any other screws with the adhesive. could be a costly and frustrating endeavor.
Call me weird but if you have a good knife: Sebenza, Spyderco, Benchmade etc. with a good warranty and service department and you cannot adjust it to your satisfaction by the methods recommended by the manufacturer I would try sending it in. Loctite, plumber's tape etc. should be a last resort thing, imo.
I'm just curious why anyone would go through the trouble to drill out a pivot when some applied heat will do the trick.![]()
spite?
i dont know, i had read that somewhere about crk.![]()
