Log Cabin In Progress...
That looks to be a beautiful cabin, superb craftsmanship, in lovely surroundings.
Such attention to detail is great to see.
Thanks for sharing.
Wow, very inspiring I own 33 acers upstate NY and have done nothing with it in 19 years. Geting tired of the grind of working 7 days a week just to keep up with the taxes on long island. Maybe just sell the house and build a cabin. Do you think I can get wireless intent there.
I'm still waiting for my invitation to come help out. Hell I'll provide the brewskis and sammywiches.
I regret that in spite of the apparent interest in this topic we have not continued the thread. One reason is simply that during the (8+month long) "farming season" much of the computer-related work needs to take a back seat. And, as destiny would have it, we were moved to put off the finishing of the cabin until more pressing matters (among them other building projects -- like a bee house, a root cellar and a new barn) received attention.
Of course, the few photos we sent were not meant as a "how-to" piece -- to necessarily be followed up. For one thing, there are stacks of books that outline the step-by-step process of log structure building -- so anyone desiring written guidelines is (potentially) well served. It is true that practically all contemporary how-to manuals on the subject consider a chainsaw a given. Consequently the described techniques of log squaring, corner joinery, etc. are, unfortunately, chainsaw-dependent...
Nor were those photos meant as a little show of the "look, we're cool" kind. Rather, the core message was simply the re-stating of what every backwoods person of this continent knew 100 years ago: To build a home from standing trees, the only tool one really needs is a good ax.
We did use additional tools, simply because they were at hand's reach, made the job easier or quicker, and still adhered to the hand tool principles. However, I'm mindful that many of the tools we are presently privileged to own may not be available to all people needing (or wanting) to do similar work. So as I work I find myself continuously gaging the "essentiality" of them -- in my present life and in view of most peoples "less fat" future. Let' s be honest -- how many of the Earth's citizens could ever own all the tools we used in this little cabin project?
In any case, here is the list of additional tools (besides the various axes), in order of their importance (as perceived by us):
1) the buck saw or bow saw -- used primarily to cut the logs to length and to make the cross-gain cuts while shaping the dovetail joint. I should add that had we chosen to make the more popular round notch corner joint, the saw would quickly loose its merit.
2) the level -- to mark the center-line of each log end, before hewing and/or defining the dovetail joint.
3) a small (12") square -- to mark the width of the dovetail.
4) two drawknives -- the straight one for touching-up the squaring of the log's sides (primarily accomplished with a standard double-beveled ax), and an acutely curved, hollowing style one for the finishing of the groove on the underside of each log; this, of course, only for the so-called "chink-less" method of contour-fitting that is used in this case. Both of these drawknives, however, could be dispensed with easily because the side of the log touch-up is purely cosmetic, and the underside grooving can -- even if it is somewhat trickier -- be accomplished with the ax, which is how we initially remove most of the wood.
Of course, we do use a marking tool -- a soft pencil (or an indelible one when the wood is wet). It is convenient, but one can get by without it. A spike, point of a knife, thinly shaped piece of charcoal etc. can come to the rescue, if need be.
Other convenient aids are a scribe, an adjustable angle gauge, flat chisel (1 1/2") and/or a slick. Any of these may or may not be found with us on the building site. The last three of them are only useful for the dovetails, but progressively more often the chisel and the slick have been made obsolete by a nicely sharpened 1-3/4 to 2 lb ax on a 23 to 25" handle. (The two other versions we use on a project like this are a 2-1/2 and 3-1/2 or 4 lb, the latter with a rather wide 6" face, though not a bona fide broad ax.)
Please understand that all of the above is NOT a "recipe". These are simply tools that (after more than a few hours of experience) we presently use -- a "kit" that tomorrow may change...
In closing:
Taking the "between the lines" intended encouragement of that little cabin profile (just do it!) a step further, we hoped to remind the readers that the ax (as well as other human body-powered tools) is likely to make at least a partial comeback -- not as a cute re-enactment of history, but as a serious energy-conserving alternative. An ax, in my view, is not an "old fashioned" tool. "Timeless", or -- at this point in history -- "futuristic" may be a more fitting term...
Cheers,
Peter
Can I please help out? You can pay me in beer and sandwiches. I also like the fact in your pics there is usally snow on the ground, and yet everyone has what I guess I would consider light clothing on. What is the temp?
There are places around here where the air is so dry, the temp might be 17 or 18 degrees, but you can be quite comfortable in just a shirt. There's no bite to the air because there's no moisture content. McCall is a perfect example-all the water's on the ground in the form of snow, humidity is 4 or 5 % and unless a biting breeze comes up, which is odd because the mountains create a wind barrier, and it makes for a very comfortable winter experience. I learned the hard way a few times going out in comfortable weather, running a camera and in 10 minutes my fingers were numb. Couldn't figure out why until I realized I was comparing humid Wisconsin temperature to dry Idaho temperature.
Another funky thing happens in the mountains too-you get these super-low pressure pockets when a high pressure system blows up and over a valley, and draws air out with it. You can get snow in the high 30's, even low 40's, that sticks. Makes for some weird skiing snow, but for some great, easily enjoyable scenery.
Love the cabin photos, what a project. I'm going to make one of those some day, mark my words...
