Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
OK, lets get a few things worked out.
The amperage rating of any component is the amount of current it will carry before burning up. This has nothing to do with the actual current in a circuit.
If measuring the DC current, you have to have the polarity right and have the ammeter in series in the circuit. In AC, you don't need to worry about polarity, but the ammeter still needs to be in series with the circuit.
The voltage and resistance in the circuit will determine the current. I=E/R .... Raise the voltage and raise the current. Lower the resistance and raise the current.
In an etcher, the circuit is from one lead, through the blade, through the electrolyte, through the pad, through the metal, and back to the other lead. It does not matter if it is AC or DC.
The things that can be eliminated as variables for the current draw are the wires, the transformer, and the bridge rectifier if in the DC mode. These are passive components if of sufficient rating, will not affect the current.
The size of the stencil determines how much of the blade is in the circuit, and will affect the current that passes through it, but that is a minor concern, as the actual exposed surface in an etch is very small..
The pad and its metal component are an issue, and the electrolyte is a big issue. While Zaph loves his paper core Q-tips, a piece of felt over a carbon block will work much better. Other things covered with felt, like brass, titanium, stainless steel, etc. can be the electrode, but whatever it is has to carry the current without any resistance. A carbon block with about 1 Sq.In. surface has a much better path for the current than the small amount of current a wet paper tube with a tiny surface area will allow.
Personally, I would change your etcher to a carbon block before I went farther, but for the purpose of this discussion, lets assume that a paper core Q-tip will work reasonably OK.
The etch is made in the DC mode when the current passes from the blade, which acts as the positive electrode ( anode) and passes through the electrolyte to the pad block, which acts as the negative electrode ( cathode). It take some metallic ions from the blade and leaves a shallow hole where they came from. The metal ions go through the electrolyte along the current path, and get deposited on the pad surface. In the AC mode it goes back and forth 60 times a second, leaving black metallic oxides in the hole left in the blade. This is caused by the metal (iron) ions combining with the electrolyte's ions, usually the chlorides and sulfides. If all goes right the "hole" in the blade is the exact shape as the stencil, and the black oxides make it a dark image.
That leaves the electrolyte as a suspected culprit. Distilled water has no ions in it to transfer the electrons from one electrode ( the blade) to the other ( the pad). Distilled water will not carry any current at all, because it has infinite resistance. Don't try this at home, but if you grabbed a 1000V line in one hand and stuck the other wire in a glass pan of distilled water, then stuck your other hand in the pan.....nothing would happen.
You have to add something to the water that give lots of ions for the current to go through. Salt will work. There are better commercial solutions, but a saturated salt solution will work fine. Make this by dissolving plain salt in warm water until it won't dissolve any more. Pour off the liquid to a clean glass or plastic bottle and use this as the electrolyte. If the electrolyte resists the current too much, as would be a low salt content electrolyte, it will not carry much current. If it has low resistance, the current will pass through it, bringing along the metal from the blade and making a etch where the metal was stripped out. The distance the pad is from the metal also affects the amount of transfer current. The pad should put the anode and cathode as close together as possible, with nothing but the electrolyte and the barrier ( the stencil) between them. The greater the distance between the anode and cathode the higher the resistance .... and the lower the current. That is one reason why I don't like Q-tips. A piece of damp felt on a flat carbon block is about the best delivery system you can ask for. Another reason the Q-tip is problematic is it only works with lots of electrolyte to keep it wet. If it isn't wet, it does not carry the current efficiently. Too much electrolyte makes for a blurry etch.
Your comments about destroying the stencil, and the pad getting hot make me think that one or both of two things is happening.
Either the pad is not keeping the two electrodes far enough apart and there is too great of current flow. The felt pad on a carbon block provides just the right amount of separation.
Or, there is far too much electrolyte in the path and it is allowing too much current to flow.
The only other variable is the stencil size, and I am assuming it is a normal size makers mark name/logo.
Photo posting is covered in many places...one is here:
http://www.bladeforums.com/forums/showthread.php/1088317-Posting-photos
