Lone Wolf Harsey T2 Folder
Feedback: +0 / =0 / -0
Price: $146.95
http://www.theknifeconnection.com/index.asp?PageAction=VIEWPROD&ProdID=4010
Flat Rate Shipping...The “Harsey T-2 Ranger” tactical folder is sized for your pocket and tuff enough to handle any cutting task. This scaled-down version of the Harsey Tactical Folder has all of the extremely strong and great looking design attributes of the bigger knife in a pocket friendly size. The frame and locking liner are built from titanium making this knife extremely tough, corrosion resistant and lightweight. The pocket clip is stainless steel for superior spring force and memory. The blade shape is a classic drop-point and is 3.90 inches in length. The blade material is CPM-S30V high-carbon “Super” stainless steel that is precision heat treated, tempered and sub-zero quenched to achieve maximum edge retention, flexibility and corrosion resistance. The black textured & contoured handle scales are a high-strength fiberglass-filled nylon that is extremely tough and chemical resistant. The Harsey handle design is well though-out and provides finger groves and notching in key areas to assure a positive grip under any conditions. The blade has a locking-liner for safety. The ambidextrous thumb-stud provides easy one handed opening and closing of the blade. All fasteners are stainless steel and the open support-column style back spacers allow easy cleaning after field use. Dirt, sand and other contaminates can be easily washed out of the handle because there are fewer areas inside the knife to trap these materials. The Harsey T-2 is ready for any situation or adventure you may face.
Lone Wolf Harsey T2 Folder Specifications:
Blade Length: 3.90 in, 9.90 cm
Length Closed: 4.90 in, 12.44 cm
Overall Length: 8.80 in, 22.35 cm
Overall Weight: 7.00 oz, .19 kg
Blade Material: CPM-S30V high-carbon stainless steel
Handle Material: Titanium liners w/ black textured nylon scales
Pocket Clip: Stainless Steel
Fasteners/Rivets: Stainless Steel
Lifetime for materials and craftsmanship
