Look at my Wrought
I finely got around to etching a small chunk from the wrought iron chain i have had for a year. I had gotten other wrought iron with the chain but the pattern is to fine and it does not show up when etched so i thought the chain would be the same but i was wrong. I cut off about a 1/2" from the end at a 45deg angle and sanded to 600 grit and was amazed at how reflective it was. I showed some people at the shop and thy where very suprized it came from 600 grit. but any way i etched it for about 1/2 hr and pulled it out and washed and scrubbed it, i could see a pattern but very faint. so i repeated this 2 more times and still was not getting a deep pattern. you could see the pattern when the light was just right. So i decided to try and bead blast it very lightly to see if it would remove the silica slag and produce a deeper pattern. i blasted it very lightley from like 1.5' away and bam there it was clear as day. so back to the feric chloride for another etch then a wash and a light polish with 600 grit paper and this is what i got. I etched the 45deg angle as i wanted to see a cross cut etch through the material to kinda give me an idea of what it was like. It looks absolutely amazing to say the least, i was shocked at how beautiful the pattern was. I am going to try another chunk tomorrow but only etch it for one 1/2 hr then blast and then another light etch for 5 min then polish. I think this will get rid of the little pits from over etching. but so far so good don't you think.
here is a picture of the chain, you can see the hand forged hammer blowes and welds on the links. Its very cool.
I do the same. I just finished a friction folder with wrought bolsters that look like this does.The more slag and silicates present in the wrought the more character you will have when deep etched.
Man, its even prettier as end grain. Very cool!
