Look for some general help. Looking for a knife I can abuse and trust my life to.
One mans use is another mans abuse. Many say i abuse my knives. I say i use my knives. I do NOT throw any of them. I do routinely baton the living snot out of them. I do it in a controlled setting, so if by chance it does break, I am only out the cost but not my life. I have not broken any yet. I do know what they are capable of though. I do not chop or baton into the ground either. I have dug with them though. Man that sure dulls them quickly.
I'm a new member here but a long time appreciator and collector of blades. One thing has been consistent with my opinion of particular knives as with anything else: change. I've gone from one end of the knife spectrum and back again, but what I've ultimately discovered is that use shapes long-term preferences. That means just buying a few, preferably cheap but well-regarded knives, and going on the adventures required to test them really will determine what works for you. Then, when you get an idea for what kind of edge retention you'd like, handle shape, blade shape and length works for you, spending money on this new hobby doesn't seem so haphazard.
For camping or hunting adventures, I'd recommend a two-blade combination. One for food-prep and light stuff, the other for heavier stuff. If you're hunting, definitely keep one edge in reserve for meat processing if you're after big game. The Rat-1 by Ontario is excellent for the price point as a hard-use folding knife that can double (kinda) as a tactical carry folder. I've had a lot of fixed blades but I don't claim to be an expert there; the Becker guys always seem to be the most enthusiastic. Last weekend, when I was doing 10-12 miles a day with thousands of feet of elevation change searching for Elk, I was perfectly happy carrying an 8-ounce Mora sheath knife. Your knives should integrate with your gear. Going lightweight? Carry a tough but dependable knife with good edge retention that doesn't require a lot of sharpening. Driving an RV? Have a knife for every job. Trust fund? Get the best supersteels available.
But, I think, having held the mike way too long and the crowd is starting to groan, you should just buy a knife and get out there and use it.
The suggestions for a robust fixed blade seem on point for what the OP intends. No matter how great the knife, however, there is no knife that can endure limitless abuse without suffering edge damage of some sort. Therefore I suggest he buys a tough knife with a thick grind and also buy some sharpening gear and commit to learning how to use it. Knives get dull in use, and nobody can feel truly independent until they learn how to keep their knives sharp.
Why not look in the knife exchange here there are
Alot of options in the fixed blade section and some
There that cost less then $100 check it out im sure
You'll find something you like !
Frank
