Looking for a $40~ camping folder for a friend
I am introducing some friends to camping and fishing and am in the market for a birthday present for one of them. He has a small swiss army knife and a multi-tool, but I think a stand alone knife would be a nice addition to his gear.
The knife would be used for general things around a camp site and while hiking, fishing and kayaking (with self defense as an additional use). We don't spend much on each other so I am hoping to find a nice little frame for around $30-$40. Some of my interests:
- 3"~ blade
- Rugged
- Low maintenance
- Bang for buck
Any suggestions greatly appreciated. Also, if you think a fixed blade would be better, or if you think I should give give him the $40 towards a nicer $70 investment or something, I would love to hear those types of suggestions as well.
Have a great day!
The black PE Spyderco Salt 1 is on sale right now at NGK for tad over $40, and meets all of your criteria. Otherwise, the Byrd Meadowlark would be a very nice, less expensive (around $25) alternative, and you can select between stainless steel, FRN, or G-10 handle scales.
I recommend a Buck 110 as well. Get one at Wal-mart for $29. If you don't have a Wal-mart nearby, you can get one for about $40 at most sporting goods stores.
Buck 110 - classic
KaBar Dozier - inexpensive ~$20
KaBar Large Dozier - inexpensive a bit more robust than the straight Dozier ~$25
KaBar Mule - tough blade, a little bigger than you were looking for, but a great camp knife. ~$43.
Byrds
Benchmade Griptillian - BM550 or BM551
full size, best lock, good steel (154cm or 440c), good grip
plus it has a clip, a must for me personally.
I got a drawer full of $30 knives that I never get around to carrying.
Here are my suggestions and a little bit on why I mention them.
25$ - Buck Hartsook Neck Knife - You can grind off the lanyard loop on the sheath and have an ultraslim knife that you could comfortably place in your wallet. It will cut fishing line, clean smaller game, whittle a spearpoint on some wood, dig out splinters etc. Mine stays in my pocket on hot, humid days and is soaked in sweat for up to 12 hours before getting rinsed and I haven't had corrosion issues. S30V with an exceptional heat treat by Paul Bos. It's a fixed blade with no scales to trap water, made of coated stainless steel. It doesn't get lower maintenance than that unless you make it out of something like titanium or H1 that won't rust. Holds an edge for a long time too. It's blade is a little shorter than you asked for, but this knife is still very capable in my opinion.
45$ - Spyderco SALT Series - I haven't used one myself, but I have used the knives their design is based on. Lightweight, rugged, capable folders that simply will not rust, period. If a lot of your camping activity consists of the fishing / kayaking side, these might make a good choice. The only maintenance they'll need is some rinsing out and sharpening once in a while.
25$ - Byrd G10 Cara Cara - These are low-priced knives with extremely rugged construction and high quality blade steel. The steel is slightly more prone to rust than a Buck 110, but is more durable and will hold an edge much longer. Thick steel liners and G10 scales ensure plenty of handle strength. The design is extremely comfortable and fairly versatile. The choil and blade shape make for a variety of possible grips. This is one of my favorite folders.
25$ - Kershaw Storm - A robust framelock folder made out of a quality stainless steel. Features a recurved bladeshape which can be useful in certain applications. The handles might be slick around water, but the guard makes it pretty safe to use regardless. Just something a little different that you might want to consider. You can check these out at Walmart.
25$ - Victorinox Alox Farmer - I know you said he has a SAK, but to me this is THE Swiss Army Knife for the outdoors. The strong Alox handles and a very useful tool selection are the reasons why. A stout main blade, a wood saw, two screwdrivers and other useful implements. Out of every knife on my list, this is the most versatile, and aside from the Spyderco SALT is the most rust resistant.
10$ - Opinel #8, 9 or 10 - You probably won't choose this because it's high maintenance compared to the others, but it's a good knife so I'll mention it. The thin blades slice much better than many of the other knives mentioned in this thread and sharpen up easily since they're carbon steel. However, you have to watch out for rust with these, and if you don't treat the handle they can swell when wet. They're great knives for the outdoors, but if you can't be bothered to give it the extra care carbon steel demands then don't bother with it.
10$ - Moras - There are many stainless steel models to choose from. These are extremely low maintenance, being incredibly easy to sharpen due to the scandi grind and very corrosion resistant. The thin blade, like the Opinel, cuts extremely well. They're very durable knives. They're small and lightweight enough to stuff in a pocket or even wear around your neck. Personally I think one of these would make a much better choice than a folder for your intended uses. www.ragweedforge.com has a nice selection of Moa's and Opinels, and is run by quite a gentleman. Give it a look.
I suggest the Benchmade Monochrome
Very nice framelock, rock solid, inexpensive and decent steel.
By the way, welcome to the forums!
BETO
Sorry for my english :o
Kershaw Vapor, Kershaw JYD, Benchmade Vex is close to that price range and is a liner lock, also for a little more a Blade-Tech Pro Hunter Lite but it is a lockback. Good Luck! Kevin:)
If your going to stick with a price tag of about $40, I also recommend the Buck 110.
Get them a handful of Mora(s) for the outdoors. Fixed blades thrive in the dirt, fish guts, and rough handling environment of the outdoors. Folders cope with it, at best.
Just my .02. Please don't kill me with all y'awls Rukuses and the like.
I noticed Wally World has lowered the price on their Buck 110's. They have them for a rock bottom $26.88 now.
I picked up a Kershaw Storm II last week and really like it. It's a sturdy, made in USA knife for about $30
Many thanks again for all the great suggestions and real world information. I am leaning towards the Buck 110 but am still researching all the other listed models. You have got a great community here, kudos.
