I would say youtube it, I free handed my friends smith diamond sharpener and it came out with great results
I bought a DMT Diafold Magna-Guide Sharpening System and the stones are hitting the clamp and skipping over the blade at the higher settings (lowest inclusive bevel). It's being a real p*sser! :grumpy:
Anyone with one have any tips as the instructions are almost impossible for me to understand.![]()
It looks like your issue at the lowest setting could be because your blade is too narrow. If it is 1" or so wide, you shouldn't hit, even at the lowest setting. If you are hitting the thumbscrew, try adjusting the brass screw slightly, so you can screw the thumbscrew farther down into the clamp.
If the blades are really narrow, like a Swiss Army Knife, then you won't be able to use the bottom steps. On something like that though, it isn't really going to matter, as the blade is so thin you won't really need a huge back bevel.
ETA: It looks like a Buck 110 will give the issues you describe at the lowest setting. It is a 13/16" wide blade. Moving up to the next lowest setting would give you @ 20* per side, and no hitting the clamp. On something narrower yet, like the SAK blade mentioned earlier, you are getting into some territory that is more difficult for the system at its lowest angles. The upshot is that the stones are excellent for freehand as well, if you have a knife that doesn't work well in the system.
