Yes, Darrel, San mai would work great, forgot about that. And Kevin you have a point that not all damascus has nickel, but was responding to the idea of using Del's O1/L6/nickel since that had been mentioned earlier.
now then, the rest of this may get a little long... I want to start by saying that my razor(and so far my only razor)was made differently than most of the ones that I have seen, but then, I made it for myself. I had examined razors that were hollow ground on what looked like a 10" wheel and had a 1/8" or 5/32" spine, some were a little thicker than others. but this gave the razors a thin edge that could be honed several times before it began to lose effectiveness. Since I did not have a good contact wheel at that time, and quite frankly do not like hollow grinding, I changed direction. I started with 3/32" thick 3/4" high flat ground to a zero edge. the only bevel I have on my razor is the one that the stropping leaves. When it comes time to actually hone it again, I lay the entire face of the razor on my diamond stone and sharpen it that way, keeping my original angle, but thinning the blade ever so slightly with each full sharpening. The finish on it is 720 grit as that is the fine diamond grit(the coarse is 350). While a mirror polish may look great on a razor, any polish above the cutting edge will not help the cutting at all, a high polish may help some steels resist staining longer though.
Now, to open a can of worms
I feel that a carbon steel is better than a stainless steel for a razor. It is possible to get a shaving edge on a SS blade, but SS and a lot of other higher alloy steels like to form carbides that are larger than the edge that I want for shaving, I feel that a simple steel can be sharpened to a finer edge that will make shaving easier, with less pulling. I also feel that if you are taking the time to shave with a straight razor, you can also take the time to wipe your razor dry, and when necessary oil it, thus also preventing rust.
I can also vouch for the ability of SS to shave with, as several times in the past, when I worked in SS construction, I left for a two week trip without a razor. being stubborn, instead of buying a disposeable razor, I would sharpen and strop my Leatherman main blade and shave with that.
