- Oct 3, 2016
Hello,
I have started on my next knife. I would like to try using a sabre grind, one (bad) reason is to save a bit of time on the filing jig another (better) is that I also like the look and would try to make one.
What I worry a bit about is that when I have done grinding and when I sand the blade (both the grinded part and the not grinded which will need sanding after heat treatment) The shart separation between the two parts of the blade will be smoothed out by the sanding process.
Do you have any advices to avoid this.
Here is the current state of the knife (not quite as happy with the shape of it as the previous one, I had to make the kick at the end of the tang more pronounced that I really wanted to hide an overzealous hacksaw cut.
The holes are big as I will use mosaic pins for the first time.
