- Feb 28, 2003
arty said:I don't own the Hi version, and I am not an expert on swords.
What little I know tells me that with Hi - you are getting a Nepal interpretation of a Katana. A Cold Steel is not a traditional katana.
Neither are the cheaper Katanas (<250) from most makers.
A traditional katana has a blade that is differentially tempered by coating it in clay and dipping it in water during the treatment process. The more expensive ones have folded steel blades.
The edge is likely to be very hard, and I would not try to chop poles with it. Some less expensive katanas are through hardened, i.e. spring tempered. This varies by brand.
The handle of a traditional model can be removed and is shaped differently. It is attached in place by bamboo pegs.
In terms of functionality, I would expect that weight and balance would be different, because of the handle on the Hi sword.
The Hi swords are very tough and strong from reports on the forum, and good values.
cold steel khurkis are to HI and other khukris, as cold steel (bussee, and criswell comes to find; and anyone else that does stock reduction) are to traditional japanese blades. they're not. my OPINION is that an HI katana is not a japanese style katana either; it's inspired from. that said, they seem to be fantastic users, i imagine they handle differently, and require entirely different subtle skill to use. some of the cutting techniques applied to japanese katanas probably won't work as well - i imagine HI's are a bit tip heavy). i'm guessing HI's are also differentially tempered which is good.
i'd be intrquied to see this discussion applied to the HI type zen/tai-chi styled swords. those are of particular interest to me.
bladite
