Well, I just used the 600 grit Moldmaster stone, and I am surprised at the amount of junk coming off the stone! It isn't metal, so it must be the binding resin. There is actually a pile of it and it looks like clay. I'll get pics later. I have to say, that this is disconcerting, as I may have to get a different stone for the 30micron stage (about where the 320 grit EP stone is). I did not see this kind of stuff when using the 120 and 240 grit MM stones.
I did a couple swipes with it dry at first (because I forgot to wet it), and I could see the dust flying off of it. I'll try it again, but it seems that it's going to wear down really fast. There was nothing like this with the 120 and 240 stones, which is why I was surprised to see it with the 600.Use the 600 grit moldmaster stone dry.
That's a lot of swarf! MM 600 stones really sheds a lot since its soft, if you want to stick with it try using it just damp with edge trailing strokes a bit like using a strop with very little pressure. I find that if you use push/pull strokes, the edge will cut into the stone thus creating a lot of swarf. I moved to using the flex 600 since it sheds less and gives a better polish. The more it loads up the better polish I get.
It works really well in doing a mirror(assuming you followed proper progression) especially when it's already glazed. It is softer than the the lower grits but when used dry with not a lot of pressure, you can make it work. You can always get the flex or if that's still not up to snuff, the choseras.![]()
