- Sep 15, 2013
Definitely a good choice
As I said, Koenig Atrox, but it may be over your budget or just illegal to carry in your locale.
. . . and possibly common sense as well.High strength steels aren't that common in folders. It's easier to find corrosion resistance or very high wear than high strength because of market demands . . .
Well A tougher steel should be able to be taken down to a smaller included angle? And a finer grained steel should be able to be taken to a sharper edge. I have no problem with sharpening a knife so wear resistance is not a top priority. I do have a problem with any steel that will chip so these super hard high carbide "super" steels are not my cup of tea apparently.You can get s90v sharp, but you can't get it 1095 sharp. And I'm sure somebody gonna say well I can sit down with my new fangled wiz bang sharpener and in an hour I can get s90v as sharp as 1095. But think what you can do to 1095 if you took an hour to sharpen it.
Comes right down to it, 420HC, tho' often dissed here, is a very tough steel, in addition to being highly corrosion resistant and easy to sharpen to a hair-popping edge. Doesn't have the high carbide content of S30V, D2, etc. but in day-to-day use it's fine for millions of users. Used side-by side with the fine-grained Sandvik steels like 12C27, it would be hard to tell the difference IMHO.
Maybe YOU can't, but some of us have no problem.![]()
Yes, that's a good argument. I just wonder if most people think about taking their edges down to a smaller included angle when they go shopping for high toughness folders. I suspect not or more folders would be made out of high toughness alloys. It's more likely they equate high toughness with hard use. And I reserve hard use for fixed-blade knives. YMMV.Well A tougher steel should be able to be taken down to a smaller included angle? And a finer grained steel should be able to be taken to a sharper edge. I have no problem with sharpening a knife so wear resistance is not a top priority. I do have a problem with any steel that will chip so these super hard high carbide "super" steels are not my cup of tea apparently.You can get s90v sharp, but you can't get it 1095 sharp. And I'm sure somebody gonna say well I can sit down with my new fangled wiz bang sharpener and in an hour I can get s90v as sharp as 1095. But think what you can do to 1095 if you took an hour to sharpen it.
Nope, sorry your not any better at sharpening a knife than I am. I stand by my statement.
If you can't sharpen something like S90V then well......![]()
I did not say I couldn't sharpen s90v, I said given the same starting point, the same amount of time, and the same equipment the 1095 is always going to be sharper. And when you get them sharp the s90v is probably going to chip in any real world environment while the 1095 is not.
The advantage of a tougher steel in a folder is the edges hold up to abuse more, less chipping. The disadvantage is that tough steels are not stainless and in a folder with all the hidden nook and crannies that can be a problem. I would not mind a folder in 1095, A2 or 3V, I won't go out of my way to find one. M4 is a good tough steel also and I know there are many folders made out of it.
Ah, no..... Sorry dude....
Sharpness is the actual measurement of the apex measured in nano-meters and I know I can get them to the same point.
I use S90V pretty much everyday and it's thin at .006" behind the edge, haven't seen any chipping issues even cutting through bone.
