I'm a bit confused about the melting issue. I just watched Don Fogg grind billets red hot from the forge on a belt grinder (rubber) prior to cutting and folding. No problem to the wheel. That metal was probably about 1500°, yet the rubber didn't melt. Rubber may have a higher melting point than polyurethane, but not that bloody high.
Seemingly, it would take a lot more than 185° heat in the piece your grinding for a heck of a long time for the contact wheel to actually melt. I just can't imagine building up that kind of prolonged heat grinding myself.
I don't know who the guy was on another forum who had some difficulties, but I do know the guys on this one who use them professionally successfully. Thanks for the intel Ed (and Tracy)!
Go for ten inch, especialy if you are going to be grinding thiner stock (1/8") The extra height you will gain from the bigger diameter can be very handy.
Many moons ago I turned my wheels from 2" thick PVC. I centred the main wheel in an 8" diameter baking pan I stole from the missus. I used a two part pourable rubber mix called "flexane 80" to fill the half inch void between the wheel and the cake tin. When it cured I cut the tin away, dressed the rubber and hey presto one contact wheel.
Peter
