Looking for knife input
I hope I'm in the right place. You guys seem to spend alot of time in the woods. I'm a custom knifemaker names Andy. What I'd like to know is what you look for in a carry to the brush knife. Please, I am not looking for examples of knives. More of the following:
Blade length
Blade style
Blade steel, carbon or stainless
Type of grind
Handle material
Guard, half, full, no guard
Handle length
What you expect from a knife, what features are important to you.
Thank-you in advance for your time. This info will be used for a future project
Andy
Blade length- 4-5 inches
Blade style- drop point or maybe a clip
Blade steel- Tool steel
Type of grind- Scandi but my opinion may change when I try out a convex edge
Handle material- micarta, wood or my favorite, stag antler.
Guard, half, full, no guard- half guard, nothing on top
Handle length- doesn't really matter to me as long as it fits, Id say 4.5".
A lanyard hole and good ergonomics are important to me as well as an overall tough knife which still slices really well.
Well thats what I like, as you can see there are many options.
Here's my rough prefferences:
Blade - 9-11cm
Handle - 11cm
Blade Shape - Drop point, Flat or Spear.
Steel - Carbon (O1 is +)
Grind - Flat, Scandi or Convex
No Guard
Micarta or Wood handle
Full-Tang
No choil of any kind and blade should be as close to index finger as possible - - no huge riccaso (sp?)
Blade Length- 9-11cm - - if 9cm blade should be 15/16" wide if 11cm blade should be 1" wide (roughly)
Blade thickness - No thicker that 1/8"! 3/32", 7/64"or 1/8" are all good. 7/64" is good with 9cm blades and 1/8" is good with 11cm blades.
Handle - 11cm
Blade Shape - Drop, Flat or Spear.
No Guard
Full-Tang
Handle should be ergonomic and have an oval-ish cross section.
About a 4-inch blade
About a 4.5 inch handle, no guards, fairly simple but comfortable (thick)
Edge comes right up to the handle
Drop point blade shape
full flat grind
Carbon steel--O1 and 1095 are great
micarta or wood scales, full tang
Length 3.5"-4"
Convex or scandi or flat grind.
Micarta, wood, or stag
1095/O1/A2/52100 carbon steels
No guard
Edge brought close to handle/scales for notching (very small ricasso or none at all)
Full or stick tang
Forgot to add. Around .125 " thick.
i think that some common themes found in this forum, and that i agree with, are:
around 4" blade for a general bushcraft knife
convex or scandi grind, full flat with convex edge is also popular
simple carbon steels and a few higher-tech steels (like 3V) are popular around here...
a half gaurd/finger lip if at all
it seems that few people here like a large ricasso/choil
beefy, sturdy tang
really nice comfy handle, i see micarta alot for its toughness and texture, as well as some good classy woods like osage orange and various burls
either a drop point or a straight back are both common around here, i don't see too many clip points featured...
not too thick of a blade (ie it should cut really well, not wedge in material), but this is related to grind.
bear, i have a couple of blanks waiting for the new grinding belts to arrive :thumbup:
Andy (and our forum members),
Let's work backwards from the tasks the knife will need to perform in order for us to meet our needs in the woods. Andy, you can see from the general descriptions that the knife need not be a big chopper, but also not a tiny 2" blade. It should be able to work with wood extensively, and at a minute and detailed level: carving and whittling. The spine should be strong enough to take the beating of a baton, and the edge should be thin for expert slicing (I want to be able to shave wood into hair thin pieces, or carve chunks -- so it should be balanced in a way that I can use a high level of finesse, but also really drive it through different materials.) It should be able to skin an animal - AND clean the animal. You can skin an elephant with a 1-2" blade, but you need extra blade length to get up into the innards to remove them easily. A nice curved belly with a drop point or spear point, about 4-4.5" as many have said, does both well.
When you get into a 5" blade and above, you start to lose the ability for fine work (just barely), and when it goes to 6", 7" etc., it definitely starts -- depending on the blade geometry -- to move into the "one-job only" category: chopping. I want to be able to drill holes to start a fireboard, so the drop or spear point really makes this easier.
As others have mentioned, the most-used part of a bushcraft knife is the portion nearest the choil/handle. That's where you whittle, notch, and carve wood. The bellied tip is where you skin and dress game, and drill holes. If the choil is long and wide, or if it has a finger-choil cutout between handle and blade, it reduces or eliminates the ability to do this close work.
The handle should be smooth, minimal guard, and should not create hot spots from extensive use. It should be contoured just enough to keep your hand from slipping up onto the sharp edge easily, but still accomodate the ability to "choke up" and use the blade upside down to spin wood and notch it. The plane of the edge should not be too far below the plane of the bottom of the handle. When that happens, it's awkward to choke up on, whether upside down or right side up for whittling.
Full tang is a must, whether hidden, or exposed with scales. I prefer exposed tang with scales.
The balance should be just forward of the handle enough that it is not top heavy nor handle heavy. It should be fast in the hand and easy to control.
There's so much more, but hope my little addition to the other members' responses helps guide you.
Blade geometry should be convex. flat ground, or -- as some prefer -- Scandi (although I personally don't prefer that one to the others). Convex is king for me. I find that, with convex grinds, a smaller knife suddenly can do very big things - without losing the ability to still do the small.
No sabre or hollow grinds, no black coatings. They all impede on your ability to maximize control, or are too thick or too thin/weak to be all-around bushcraft blades.
First and foremost, we want the damn thing to cut and cut! Too many makers grind thick blades that are awesome for prying, but too thick and unwieldy to cut with. If it's tactical, it's not practical for WIlderness/Bushcraft.
Thank-you guy's alot. Siguy I have looked at a couple of your knives look-in good.
I have a free week-end this week,(taking a break between orders)and have been wanting to make a good field knife. From the input here I think I have a good idea of what will work. I'll post pic's here when its finished. Oh yes and Bear I'll be in touch for a review.
blade length should be 4-5 inches
blade style shoud be simple but functional, nothing too off-the-wall
carbon steel for sure
grind, scandi
handle should be leather, wood, stag og a comfortable synthetic
NO gaurd
handle length, in proportion with the blade
a feature i like is some jimping(i dont know if that is the right word) on the spine and it should have minimal thickness
Personally, this is my ideal specs, and is what I plan on making once I have the resources to get back into knife making.
Blade length - 3.75" to 4"
Blade style - Drop point (kind of like a spear point, but with a pointier point, if that makes sense)
Blade steel, carbon or stainless - CARBON only, (O-1 or simple 10xx)
Type of grind - Scandi
Handle material - Wood, leather, antler, or bone, or a mix
Guard, half, full, no guard - Absolutely No guard
Handle length - 4.5" roughly
What you expect from a knife, what features are important to you. - Easy to sharpen, comfortable handle.
Some things you didn't mention:
Blade thickness - 1/8" or 3mm
Tang - Full, hidden tang (ideally the end peened to the butt of the handle)
Spine - Squared sharply for striking a firesteel
Edge - Should meet the handle, no choils or ricasso's or whatever you call them.
I think most have already been said, I'd just add you need to draw a line between some small multi tasks knife, and some larger tool (big knife, axe...) that would handle heavier work.
One important think I'd like to point is that handle should be comfortable in all important grips, notably reverse grip which is often used for "power strokes" when whittling.
You may want to pick a "bushcraft" book from Kochanski (about $10, not that I am an Kochanski integrist but the book does cover the subject of knifecraft pretty well), and check all grips and uses are "covered".
As for thickness, my recommandation would be the thinnest possible that still retains enough strengh to live up the tasks.
