It's seems they dont make 6-32 in 1/8" lengths in torx.... Might just have to stick with hex.
Electricians use 6/32 and 8/32 very frequently. As such, most good wire strippers have a threaded hole in both sizes that allow you to thread in the screw and then cut to size. As you back the screw out it cleans up the threads for you. Just a thought. I prefer the Klein tools wire strippers.
Good sources already listed...
I have the Klein pliers and they are really nice on most screws... the ones I use on my folders seem to need something a little cleaner though. I like to tap a piece of steel with a few holes and use it as a jig to grind everything flat. The total overkill method I use is 120 grit on the grinder... clean up with a few passes of 400 paper if you like then hit with a scotchbrite belt.
The jig only takes 5 minutes to make and works great to shorten screws. I customize every piece of hardware I use...
