Looking to start knifemaking
Ok I'm looking to begin knife making as a hobby. I'd like to start out making small fixed blades with the stock removal method. I'll be getting a 2x42 grinder from sears http://www.sears.com/shc/s/p_10153_12605_00921513000P?prdNo=3 but that will be down the line after I learn filework.
I would like recommendations for other basic tools needed to get started. (I/e files as in shape cut etc. drills and required bits) I was looking at craftsman since they replace them for free but I have no clue what cuts or bits I need. Also any other simple tools I should get (assume an empty shed with a workbench clamps and sandpaper)
Steel I was looking at working with was 154-cm or 440c and i'd be making smaller fixed knifes if that helps.
I'd like to keep my budget for hand tools under $150 but will break that if you guys deem it necessary.
Thanks in advance.
All the information you need is in the stickies. This question gets asked several times a week, so they have made a point to put all the newbie information in one handy place.
A heads up, Craftsman does not have the same warranty on all their hand tools any longer. I think it is only on the US made items but you might want to check into that before you buy Craftsman.
Ok I went over the stickys but I still couldn't find out what type of bits (size and brand) I should pick up.
Did you expect to?
Seriously, just get a set. We can't tell you what sizes because we don't know how you want to make the knives. Do you want to punch a lot of weight reduction holes in the tang? Will you be doing full tang or hidden tang? Will you be making your own guards? So many things determine what variety of bits you need. Just get a full set of good bits.
