- Dec 6, 2013
Siegle- Kind of a hybrid cleaver/small hatchet. 5160 steel, 1/4" thick. 11" oal, blade is 6 1/4" with and edge just over 5". Scales are a brighter green G10. Comes with a kydex sheath, no Tek lok. Has not been used, carried or sharpened. Has some scratches from sheath insertion-
Spydrco Elmax Mule- Has been used, carried and sharpened. You can see scratches and marks in the pics. Very sharp. Comes with a nice tooled leather sheath. Scales are Corian-
http://imgur.com/a/Smq0fDU
http://imgur.com/a/XjHCLcj
http://imgur.com/a/geG63lb
SW R7 Military Proto from Cabo Wabo- Black coated blade, scales are black paper. Has not been carried, used or sharpened
https://imgur.com/a/RaPsj5A
White Wolves/Woodard Combat Auto- 4" Blade. Aluminum handles. Overbuilt and 4mm thick blade stock. Has not been carried or used. Comes with a belt sheath. Fires hard and no blade play
https://imgur.com/a/w1CXkvl
GG&G Hawk- Black s7 coated blade 3/8" thick. Only has one spot where the finish is peeling. Black g10 scales. Has not been used, carried or sharpened. Comes with sheath
Custom Hawk- roughly 5/16" ultrafort head. OAL is 14" or so. Satin flats, semi mirror bevels. Roughly 7 1/2" oal for the head, the edge is just under 3". Handle is a single piece of red anodized aluminum. Fills my medium hands well. Has replaceable rubber rings to assist in grip. Hardware is Ti. It's a breaching/rescue axe so the edge isn't sharpened. No sheath. Has not ben used, carried or sharpened-
https://imgur.com/a/Wlzua72
Smith and Wesson 960- First production run 6 1/2" clip point CE satin blade, 3/16" stock. Has insertion marks from sheath. Has not been carried, used or sharpened. Comes with correct leather sheath
http://imgur.com/a/vnR44xJ
Schwartz Ti hawk- 18"OAL, Edge is roughly 3 1/2", stock is slightly over a quarter inch. Has a hammered/post apocalyptic look. Has matching zombie green/black paracord wrap. Spike isn't sharpened, but it is very pointy. Comes with a zombie green blade cover. Has not been used, carried or sharpened. In the condition received.
Second blade is is a ti/cf blade. Blade is 5", combo edge with one carbidized edge. CF has been secured to the TI core using sheer strength epoxy. Matching green paracord handle. Blade thickness is approx. 3/16th". Comes with a green sheath. Has not been carried, used or sharpened.
https://imgur.com/a/68eifUa
Crawford Hawkbill Intregral -3.5" bead blasted blade. Handles are made from one piece of 1/4" thick 440C. I have carried it twice, has some minor snail trails. Snaps open with authority, very sharp.
Has the original edge
Matthew Cody Hawkbill- 3 1/4" acid washed 3v blade,OAL is 7 3/4", liners are ti and the scales are coyote brown G10. Has been carried and used lightly, edge is original. No blade play, flicks open easily and is centered. Pocket clip is ti also
https://imgur.com/a/q7BKkO0
Looking for TAD gear, Voormi, TNF, Arcteryx, size 11 boots and shoes.
Larger choppers, Spyderco, Benchmade fixed and folders. Wool.clothes and blankets
Let me know what you have!
