Thanks, @Larrin
By the way, can you verify that the info reported by @shqxk in the quote above is correct? I've been operating under the, perhaps erroneous, impression that CPM Cru-Wear had higher corrosion resistance than 3V. Can you clarify, one way or the other? (I imagine they are probably close.)
I don't mind being put right...and perhaps that is an indication why my small 3V fixed blade has fared so well these past twenty or so years.
Thanks in advance.
3V and CruWear have the same Cr content but CruWear has more carbon. That makes it form some chromium carbide and somewhat reduce the corrosion resistance.
I updated those ratings after performing more experiments: https://knifesteelnerds.com/2019/10/14/corrosion-resistance-testing/Not to nitpick, Larrin, but that does not match your estimates here http://knifesteelnerds.com/2019/01/14/which-knife-steels-have-the-best-corrosion-resistance.
