Low heat thermal cycling and hardness question.
So, in reading many posts over the last few days along with looking through some specs in HTG, I was wondering if anyone has done any definitive research on how low temperature thermal cycling affects knives. The case I have in mind is knives that are regularly run through a dishwasher.
As far as I understand it, repeated exposure to 140-180 cycles of around 1-2hours for several years should temper the blade, causing the softening/destruction of the martensite crystals. If I interpret Verhoeven and HTG correctly, we temper at 300-500 for 1 hour cycles because that is a useful way to control the temperature in cross section, and still accomplish tempering in a reasonable period of time to avoid stabilizing any RA. I have also read (somewhere?) that if you bake a knife at 300°F for a longer period, softening continues past the target HRC. So, it seems that by running a knife through a dishwasher many times at lower temperatures should effect the temper over time. Some quick estimates for a 1.5 hour dishwasher cycle, 3 times a week for a year indicates 156 hours of heating over 104 cycles seem to indicate that if the crystal structure is affected, even slightly, at lower temperatures that the blade soften due to the immense time spent heated.
If anyone has a hardness tester, a test of this would be relatively easy I think. Find a set of knives (my mom has some cutcos that fit the criteria) and test the hardness of a rarely used knife vs a favorite one, you could see if there was any difference. Also, is my theory correct?
I think worrying about asteroid impact is a more important concern.
The temperatures of a dish washer, and the amount of time at that temperature, are far too low to cause any aging. Below 300F there isn't any concern at all.
The data you are looking at is relevant to extended hold times, not accumulative time. With each cooling below Mf the clock restarts. Multiple temper cycles at the same temperatures are for tempering the newly converted RA, not adding more temper to the previously tempered martensite.
What I am saying is ( not real numbers) 400F for two hours will do about the same as 390F for twenty hours. Temperature is a many times greater factor than time, but time does have an impact. I doubt if anyone has extrapolated this to hundreds or thousands of hours at continuous temper, but the effects will taper off to near zero at some point .
It is sort of like a farmer picking up 100 pound sack of feed, and doing it ten times a day. In a year he picked up 365,000 pounds....but that is not the same as picking up a 365,000 pound truckload of feed.
I agree with Stacy but had to chime in to ridicule his math skills...
...picking up 100 pound sack of feed, and doing it every day. In a year he picked up 365,000 pounds...
You don't get many opportunities to correct that guy and I couldn't pass this one up.... Ha!
