- Oct 24, 2013
Up until recently, my experience in forging has been limited to 1018 and A36 steels. Hot working these higher carbon and alloy steels requires quite a bit more elbow grease than the former medium. I've been doing my homework and reading up on the many options I have available to me when it comes to forging a blade. The only thing that seems to remain consistently crucial to every steel is the heat input and heat treatment; you end up with garbage if you ignore one, the other, and especially both. I understand that some steels are more forgiving than others, one coming to mind is 5160... Stacy's three step process in 5160 grain reduction/ then quench brought me to this question. Granted I was working with a leaf spring, not knowing it's true composition, that little tidbit from raised a great bit of curiosity, and I've been reading up on the proven theory since.
When it comes to forging a blade of known steel, would I benefit from utilizing a controlled temperature furnace as a forge?
The industrial heat treat oven I'm working on getting back into service seems to be a legitimate workhorse when it comes to the rigors of heavy use, and I like having that kind of control over heat input. I would probably work multiple blades at a time, cycling through them in order, enabling them to return to forging temps after each heat. An added benefit hear would not having to worry about overheating the blade, because upon reaching the desired forging temp, they would just soak. Any input will be well received and appreciated.
** The catalyst to this question comes from Ed Fowler's Knife Talk 2; "Uncover the Secrets Hidden Beyond the Blade" (pg. 116)
