Cool - 7dps is quite acute/thin, need more details on 'microbevel'?I’ve gone as low as 7 dps with a slight microbevel and cut thin hard plastic and soft metal (soda cans) with no trouble.
Agreed. A keen 15degrees isn't strong enough to resists lateral deflection for deeper (than hair diameter thick) cuts. Around 25 degrees is excellent for non-deflecting-apex cut (esp push cutting, e.g. chisel, kitchen knives).as a straight razor maker 15degrees is the lowest total edge angle for a shaving razor. the edge just doesnt hold up and thats just cutting face hair. on my kitchen knives i might be just under 15 degrees per side so in the range of 25-30 degrees total edge angle. keep it thin behind the edge will do more to help the cut. as pointed out the main grind will make more difference then the sharpened edge angle
The microbevel was applied by hand but the intent was to be about 10 dps.Cool - 7dps is quite acute/thin, need more details on 'microbevel'?
Reason per my post of lowest possible angle - I've certain experiment/application in mind for a few applications of low wedging along with high sharpness... will conduct such experiments when time permits.
Hollow grind to 0.2mm thickness before sharpening and sharpen to 10-15dps convex should do quite well up to semi hard materials. Going to 0.1mm before sharpening is viable but risky. Under 0.1mm is for steels with excellent compression strength. Talking about push cuts.Cool - 7dps is quite acute/thin, need more details on 'microbevel'?
I'llThe microbevel was applied by hand but the intent was to be about 10 dps.
I'll be watching for the results.The microbevel was applied by hand but the intent was to be about 10 dps.
My kitchen knives are W2 with the primary bevels ground at 4 degrees with a full flat grind. They are 2.5 inches edge to spine. I put a 15 DPS edge on them, and they cut quite well. Anything more acute and they'll chip . The W2 is at 60 or 61. When I was selling knives it was important to me that the customer could maintain the edge with a bit of Otherwise the blade could be made useless on a very short time. FredThe microbevel was applied by hand but the intent was to be about 10 dps.
