Funds needed for other toys. Have two safe queens and one user watch for sale. No trades wanted. All prices NET to me and include priority shipping w/ delivery confirmation. Insurance extra and must be requested by you. International shipping & Insurance extra and would be calculated prior to sale. Paypal or USPS Money Orders only.
Lum Tec Combat B6
B6 Bead blasted 316L stainless steel with Titanium Carbide dark charcoal PVD hard coating. LUM-TEC MDV Technology®. Japan made SII NH15J movement (auto and handwinding). Black dial.
Product Specs:
43mm width excluding crown.
22mm lug width.
316L stainless steel.
100 meters/330 ft. water resistance.
SII NH15J Japan made automatic movement with handwinding.
Thick sapphire crystal.
Double side anti-reflective coating.
Threaded case back.
Screw-lock crown with double diamond sealing system.
Leather band/PVD buckle
My user watch but well cared for and runs great
$SOLD
Casio Pro Trek PRW-5000Y-1CR SAFE QUEEN, BNIB & Never worn
Triple Sensor: ABC (Altimeter, Barometer/Thermometer, Compass)
Multi-Band 6 Atomic Timekeeping (US, UK, Germany, Japan, China)
Receives time calibration radio signals which keep the displayed time accurate
Auto receive function (up to 6 times per day)
Manual receive function
Tough Solar Power--charges in either sunlight or indoor light--Tough Movement--Auto hand home position correction
Needle Indicator for Compass Direction, Altimeter Differential and Barometric Tendency
Water Proof 100 Meters--perfect for swimming and snorkeling
Full Auto LED light with Afterglow--automatically activates when you position your hand to look at the time or under dim light or dark conditions.
Digital Compass--built in sensor detects magnetic
Barometer--measures barometric pressure
Altimeter--measures the altitude above and below sea level
Measuring range: -700 to 10,000m (-2,300 to 32,800ft)
Altimeter Memory or Height Gain--sums all the meters you have climbed
Thermometer--measures temperature
*Changeover between Celsius (°C) and Fahrenheit (°F)
Low Temperature Resistant (-10 C / 14 F)
World Time--(29 cities + UTC), city code display, daylight saving on/off
5 Multifunction Daily Alarms
Hourly Time Signal--beeps every hour on an hour****************************
Mineral crystal glass--hard crystal resists scratching
Countdown Timer
1/100 second stopwatch
Auto Calendar (pre-programmed until the year 2099)
12/24 Hour Format
Button operation tone on/off
Battery Power Indicator
Power Saving Function
Stainless steel back with Tough Sports Rubber strap
Made in Japan--High quality Japanese Casio technology movement
$SOLD
Lum-tec M62 Limited Edition - SAFE QUEEN, Never worn.
PVD Blue Dial Black titanium carbide PVD hard coating. 2 color LUM-TEC MDV Technology® luminous application. Ultra precise Miyota 9015 28,800 BPH automatic Japan movement. Blue sun ray laser cut and hand filled dial. ONLY 50 made. Comes with extra rubber strap, PVD Bracelet (all unworn) and PVD buckle.
Specs:
44mm width excluding crown.
12mm thick.
24mm lug width.
316L stainless steel construction.
Screw lock crown with double diamond sealing system.
Threaded sapphire caseback.
Japan Miyota 9015 28,800 BPH automatic movement.
40 hours power reserve.
2 color LUM-TEC MDV Technology®. (applied by hand)
Laser cut blue sunray dial with all index filled by hand.
Sapphire crystal.
3 straps included:
Leather strap with matched stitching and quick release changing system. 24/22 size.
Custom molded anti-static rubber strap. 24/22 size.
316L stainless steel bracelet. 24/24 size. (matched finish)
Limited numbered series of 50.
Special 3 piece case construction.
1 year limited warranty.
Free lifetime timing adjustments.
All boxes and papers.
$825
Lum Tec Combat B6
Product Specs:
22mm lug width.
Threaded case back.
$SOLD
Countdown Timer
12/24 Hour Format
$SOLD
Specs:
12mm thick.
24mm lug width.
Sapphire crystal.
3 straps included:
$825
