Beautiful Lum-Tec RR4 limited edition with the Miyota 9015 automatic movement(with hand winding and hack feature)and a sapphire crystal. Limited to 100 pieces this is 003/100 as you can see on the case back. In excellent overall condition. Keeps perfect time and is also beautiful to look at with very bright lume. The watch has been worn but has zero marks on the crystal and zero marks on the case. It really is an awesome timepiece. The included original leather and silicone strap are both present. The silicone strap currently installed is like new and the leather strap shows a little wear. Retail is $795 I’ll take $250 shipped and insured USPS priority via PayPal friends or add 4% for goods and services. No trades on this one please.
Email or pm is best way to reach me. Thanks!
John(dot)Horner(dot)3@gmail
Specs from the web: 43mm width excluding crown 22mm lug width 11mm thick 52mm lug tip to lug tip 316L stainless steel bead blasted finish with titanium carbide PVD hard coating High tech Viton® gasket Precision screw down crown with double diamond sealing system Sapphire crystal with clear anti reflective coating Threaded stainless steel/mineral glass case-back 100 meters/330 ft. water resistance 2 straps included: leather and rubber with matching hardware Extra spring bars included for fitting other straps Precision tuned 28,800 BPH Miyota 9015 Japan automatic movement with hand winding and hack feature Calendar Thick sapphire crystal One year limited warranty Limited numbered series of 100 Free lifetime timing adjustment service.
