My bad, I should've say it clearly, its 20 and 25 micro bevel per side. I want a durable edge for outdoor knife so would not go low.
So inclusive.
Like I said earlier: 40 and 50 degrees inclusive is not "sharp" by any stretch of the imagination.
That is more obtuse/dull than an axe or hatchet.
If you want sharp go to a more acute edge. 10 to 15 degrees MAXIMUM per side.
If you want a visual, on a piece of paper, draw a straight horizontal line, then two vertical lines. On one vertice line, using your compass, mark a spot at 20 degrees and 25 degrees on both side not the vertical line. Connect then to where the straight verticals line meets the horizontal line.
On the other vertical line, mark 10 degrees on each side of the vertical line and connect to where the vertical line meets the horizontal line.
You've have a "V" on both.
That is your cutting edge. The straight vertical line is the center blade of your blade.
Which do you think is going to cut better? The WIDE "V" or the NARROW "V"? As the edges wear, which do you think will stay sharper (have the more acute angle) longer?
Thin the edge of your blade by going to a 10 or 12 degree angle on each side. Forget the micro bevel. Your knife will cut better, and require less sharpening.
I have my"outdoor" folding knives, lseveral Buck 110's, including those with CPM154, S30V, and 5160 carbon steel, as well as those with standard 420HC, and a vintage Old Timer 7OT with a 1095 carbon steel blade at 10 degrees per side, no micro bevel. Any of them will peel and gut at least three whitetail deer before they need stropped. I can whittle/carve tent stakes, hotdog/marshmallow sticks, feather sticks, trap triggers, and debark kindling if/as needed, with no edge damage.
I can also cut down saplings for a shelter with a single cut (stress the sapling, then make your cut in the outside of where it is stressed)
I've been doing so for over 60 years. THIN ACUTE EDGES work better and are USABLE longer than FAT WIDE OBTUSE EDGES.
Do this, and you'll swear your using a different knife, the cutting performance and edge retention will improve that much.
Obviously, though, you're young, and probably won't listen to an old fart.
I'm out of here.
