Don t push meAnd cuts 4 times worse![]()
Sorry for off topic guys
Thanks for the info. I think I will start at 62ish and go from there.
I read some article from Roman Landes some time ago.He says that if we compare two edge ,same steel and same hardness . One 0.10mm behind edge and one 0.2mm behind edge knife with 0.2mm behind ege is FOUR time stronger then other one with 0.10mm .
I've run my kitchen knife m390 down to 11dps with 14 dps micro bevel, worked fine until I tried to cut up really hard crusty bread then it chipped out. 61rc on that one. I was pushing it though to see what it could handle and an edge that thin couldn't take the hard bread!
Good to know! What hardness levels could aeb-l handle that at do you think?But AEBL will handle it fine. I've never been a fan of high carbide steel in the kitchen. How abrasive is food...
I made a couple hundred kitchen knives in aebl at 62 with a 15 degree included angle plus micro bevel. They held up well. you wouldn't want to use them on bone or anything like that, but bread would not be a problem.Good to know! What hardness levels could aeb-l handle that at do you think?
Thanks for the info. It would be nice to speed it up a bit. From start to finish it takes 13 hours as is.Thanks for the follow up info.
I'm not sure you want to/need to put the blades in the cold kiln. At least in my kiln that'd be a long time.
Also, I don't think you don't need to do the 1450 step. IIRC that's more for larger, thicker parts.
I've been getting similar final RC with an aus temp similar to yours X 30 min and then plate quench => LN X 1 hr => temper at 350 X 2hr X 2.
