- Nov 1, 2000
Medford uses D2 for almost everything.
20CV is another name for M390
Chart from Crucible:
Of course, geometry and hardening matter, but if D2 and similar are considered "tough," what are S7 and H13? XXXL-tough lol.
Are they tough enough for cutlery and worth it for the edge retention, corrosion resistance, etc.? Usually, but I wouldn't pick 10v, D2, or M4 for a demolition tool. Just depends on what you want and what you're doing with it.
I have a knife being made in 1/4" CPM 10V hardened to 62RC and cryo'd. It's a bowie with a 6.5" sharpened length. Toughness of CPM 10V is equal to D2 and M4. That being said, I'm not worried at all.
You can take a piece of low toughness steel and make it an inch thick with half am inch primary grind and it can do all that. Does not mean it is still the right steel for the intended application.
M390 is a good balanced steel between properties but if you want a thin knife for slicing and still want toughness you can get better options.
It all comes down to choosing your steel and heat treatment cycle for intended use.
You can heat treat M390 with corrosion and wear resistance in mind or with toughness and wear resistance in mind. Both would have the same hardness but completely different properties.
Did someone ask a question or did he come here to school us?
If by chance that was directed at me, ... please tell me more. Sounds like something that perhaps needs airing, or ...
I was merely asking what I missed, as I have interest in both m390 & 10v (two favorites of mine).
CharlieMike,
Looks like some really nice progression in your blade grinding there ++++
That Bowie is sick!!
but they dont have such edge retention capabilities
so that leaves the question, what is toughness in knives good for if a "not at all tough" steel can handle it all?
How do you define edge retention? Slow wear? Then yes. Tough steels will not chip easily as other steels, then they will have better edge retention.
Going to try and keep this simple. Less chance of issues developing such as fatigue (related to crack growth) over prolonged "tough" use and unwanted severe impact.
As an example. Ed Schempp used a 52100 in clad 15N20 for years in Bladesports while those that used CPM-M4 experienced work hardening and a blade would crack after a year or two in use.
Basically, all steels are a give and take between basic properties of Edge performance, Toughness and Corrosion resistance (in simple terms).
Read this as a good start.
http://smt.sandvik.com/en/products/strip-steel/strip-products/knife-steel/knife-steel-knowledge/
What would you need THAT toughness even for?... like.. a really really thin kitchen knife that you can baton with? that would be cool
This.. It's all give and take. That's why there are a variety of so many different steels. M390 is one of the more balanced universal applications and is probably why it is a huge fan favorite.
I don't think you should be worried about it's toughness at all.
M390 is no where near as tough as steels designed for shock. People make a mistake in cross comparison steels outside of its category. This is covered by literature.
D2 by any means is not a tough steel for construction or as a jack hammer bit, but people have used in knives for years (though it still has its own limitations)
Is M390 good enough for general use. Sure. Does it have its limitations. Jip. At extremely low angles it suffers similar fate as most high carbide steels. It chips.
If you want charpy data for all steels. Good luck as 'datasheets' barely indicate what orientation was used for the sample heat treatment involved etc.
This might sound obtuse. But a lot of this kind of discussion often relates to using a knife for all kinds of things that might be better approached with other tools. I think it often stems from a survival view about having one thing to do it all.
I have never broken any knife.
If you cut with your knife, pry with a pry bar, and chop with an axe, it allows you to pick a blade to cut, and a steel that gives you what you want for that.
A slicer, a chopper, and a pry bar are 3 different things. Combining them ends up compromising all of them, IMO.
For a slicing knife, M390 is an excellent choice, IMO.
