Ankerson
Knife and Computer Geek
- Nov 2, 2002
are you saying all rank the same in overall edge retention?
ZDP and XHP are in the same catagory with M4 above those.
M4 vs. ZDP vs. XHP: Which one holds the fine edge longest?
What's your experience? Thanks.
If by "M4" you mean "CPM M4", then between ZDP-189 and and CPM M4, CPM M4 held an edge longer by a considerable margin for me when cutting manila rope. I have not tried XHP. And I don't know about "fine edge".
Forum > Knife Specific Discussion > Knife Reviews & Testing >
Comparison of CPM M4 HC, ZDP-189, M390, and S30V edge retention
http://www.bladeforums.com/forums/s...PM-M4-HC-ZDP-189-M390-and-S30V-edge-retention
Was just thinking the same thing.I like how you didn't include your cts20cp para as you and I both know its leaps above these.
Yep, I mean CPM-M4 and by fine edge I mean that initial hair whittling edge.
No steel is going to hold that for very long if you cut something with it like cardboard, rope ect.
I understand but which one in your experience holds it longest Jim?
I understand but which one in your experience holds it longest?
Pills,never heard of that as a testing measurement before. Take a look at what cruicable has to say about wear resistance of cpm4 to s90v (wich is similar to 20cp http://www.crucible.com/PDFs/Knifemaker REV June 2010.pdf they show close to double the wear resistance of s90 over cpmm4
My bm lfti cpmm4 isn't close to my para 2 in cts20cp I mean leaps but that's probably the thick grind. I used a gayle bradley for three days and I saw wear ,not much but still more then I have with my para cts20cp in weeks of work at the same job.if its the bradley you are talking about I think you might be noticing less crumble effect because of the awesome hollow grind wich leaves almost no steel behind bevel as oppose to say a ffg of s90 or 20cp. As you start to get threw pill with a ffg past the bevel the grind of knife will push against top of pill you would see crumble from top not at bottom of cut.where as a hollow grind the only part of steel to hit pill would be the bevel and then air behind that, not to mention the bevel doesn't have to be as long on that grind to obtain a thirty degree angle as iit would on a ffg. So in turn your V is longer and wider at top.I could even see a sebenza with its awesome hollow grind of s30 excelling at this over s90 in ffg.now say you were to have 20cp reground so its ground from top to bottom like a true flat ground from top to edge like Ankerson did. (Awesome btw) you would see it excell over your hollow grind bradley
out of the three steels you listed, M4 IMO. also, because M4 is pretty tough, you could set the edge at a more acute angle and not have to worry about chipping (within reason).
which M4 knife are you looking at?
