Hi Mates,
I got this fantastic M43 by Rajkumar. Everything is outstanding. The only problem I have is the big & long handle for my small hand. When I hold the part near pommel, the balance is a bit heavy, especially when I draw it back for another swing. I'm only comfortable with is the part near the bolster. Its where the swings are easier.
Key dimensions:
- Weight: 37oz
- OAL: 18"3/4
- BL (cho to tip): 11" 1/2
- HL: 6" over all (5" for wood scale & 1" for bolster)
- Spine thickness (at shoulder): 7/16" (11mm)
- 1st pin: 1"3/8 wide x 1"3/8 thick (35 x 35mm)
- 2nd pin: 1"3/8 wide x 1"10/32 thick (35 x 33mm)
I intend to make the handle about 1 shorter by dis-assembling the slab, send it to my village blacksmith to make a shorter tang (see the red line), then I put on may be a new pair of slab. By shortening the handle, I can hold it better. However, Im still hesitating if its a good improvement or a silly action from an eager idiot. The shortened tang can affect the angulation of the knife overall. While it is long, I still have about 1" free so that the pommel wont dig my hand while chopping. When it shorter, for sure it will dig.
The other option is to leave the handle length as is, just to shave down the thickness as well as the width for more ergonomic grip. When you look at the dimension above, you can see the handle is almost round, not oval or egg-shape.
I need to get your experienced recommendation on this.
Thank you in advance.
Hung
Key dimensions:
- Weight: 37oz
- OAL: 18"3/4
Hung
