have you tryed a flea market I got a great mechete for $6Since there isn't a machete/bolo forum here, I figured this would be the best place to post it, since it is the most relevant. I am looking for a machete or bolo for bushcraft that will be suited for various camp chores. I need something decently durable and reliable, and it needs to be able to handle small saplings easily, because that will be what it is used for mostly. I have been looking around online and in stores, but the only machetes I can find near my house are crappy Coleman ones from sporting goods stores. If anyone can suggest a good one for me, I'd really appreciate it. I'm looking for something with a sheath as well, which has been another problem - I've been finding lots of machetes that don't come with sheaths online. I'm looking for something in the $30-40 range or lower.
Thanks.
I can only comment on the tramontinas, as thats the only machete I've owned. It was an awsome tool, great for saplings and the like. Great machete for the price, I bought mine for, I think 30 dollars with a sheath, now the sheath wasnt that good, but it worked fine.
C'mon Skunk, you gotta catch up!
According to the website, it's made out of recycled steel, whatever that is (leaf springs?), but definitely carbon (NOT Paki stainless). Mine arrived with about 6 pin-head dark spots, the rest was shiny. Coated in grease.
The blade on the No. 2 is 1/4" at the spine, flat/convex grind to the edge, distal taper to the point. The blade is 12" long, 3" at the widest point.
The tang is 5/8" wide where it enters the handle and the shoulder cuts are rounded (from the little bit I can see), not sharp corners, so I don't think it's going to break there. There's a solid 1" brass collar surrounding it all with some crude decoration. The tang goes all the way through the handle, tapers to what appears to be about 3/16" at the tip, peened over a solid brass washer.
The handle is 6" long, made of some kind of almost black dense-grained wood, unfinished, that might even be ebony; decorative carving at the butt.
The condition of the blade is what knife-makers here would politely call "unfinished". While the blade is well-executed, grind marks are very evident and there are some sharp corners. Somebody with a belt sander could finish it off nicely. I'm just going to take a file to the sharp corners and leave it as is since I intend to use it. The blade came sharp enough for a machete. I don't see any evidence of forging, I'm thinking more and more that this was ground out of a leaf spring.
The sheath is some kind of stiff leather, tooled, center seam down the back. There's a collar around the top with a tab for hooking over a belt. As I said, the leather has a tendency to warp (I think a lot of oiling will cure that). The other problem was the back seam was separating, I was afraid the hand-stitching might eventually give; so I cut a strip of leather scrap and glued it over the stitching with contact cement to reinforce the seam.
It's solid and hefty, a little rough in finish, feels good in the hand, definitely a user, I'm very happy with it for the price. Unlike my Tramontina, this definitely is something for chopping small trees and splitting wood.
Hey Aproy how would you compare the Valiant Survival Golok to your Himalayan imports bolo? I own a HI 15 inch ang khola myself and was wandering about how you liked those bolos and if you have any kurkris how would you compare them?
