Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
The topic comes up, from time to time, about cutting hard steel. My default answer is," Appropriate carbide cutter, rigid setup to prevent chatter, suitable speeds and feeds for the cutter size and material, blah, blah, blah..."
I've been meaning to post an example for a while. Here is a dull Nicholson file I'm going to put in a 1/4" hole.
http://nathan.broadtime.com/hard1.JPG
I'm lining my vise jaws with aluminum because the file is harder than the jaws.
I'm using a coated carbide cutter without coolant. The mill has flood coolant and in this application it wouldn't hurt to use it, but when using carbide with certain coatings in hard steel it is often advantageous to run dry. Prevents coolant shock to the cutter.
http://nathan.broadtime.com/hard2.JPG
You'll notice the cutter is undamaged and the old file has a perfect, near mirror finished hole in it.
http://nathan.broadtime.com/hard3.JPG
Here is the data:
Full hard Nicholson file, probably around 66 HRC
4 mm carbide two flute cutter (4 flute is usually better for this, but can be more prone to squeal plunging in the hard stuff)
50 Surface Feet per Minute (SFM) spindle speed, which works out to 1,216 RPM for the .157" cutter (please note folks, running at a very slow RPM, like 300RPM, isn't helpful)
.001 chip load per tooth (because it is a small cutter in hard metal), which at this RPM works out to a glacial 2.4 inch per minute feed rate.
Helical plunge with .005" infeed per rotation, which required 50 turns through the 1/4" file.
Cycle time, six minutes (because of the small infeed and very slow feed rate, could certainly be improved some)
Beer consumed: None, it is still pretty early on a Sunday.
What is the moral to this story?
A: With proper speeds and feeds and a reasonable setup, you can cut hard steel without messing up cutters.
B: I have a job I'm supposed to be working on this morning, but I'm procrastinating.
Here is the data:
