ScarFoot
- Sep 16, 2021
It’s cold in Alabama and I got bored so I thought I’d run a little experiment. I had a piece of either basswood or balsa 1” square and 6” long on my bench. I decided to use it as something between a strop and a hone. To do that I sanded 3 sides flat to 180 grit on my surface plate and impregnated those sides with diamond paste of 5000, 8000 and 14000 grit. I applied the paste, smoothed it out and then used my heat gun and worked it into the wood with my finger tip. After that I just needed a knife. I found one that was sharp enough that stropping could restore the edge without re-sharpening. It would cut normal paper but wouldn’t shave and was tearing phone book paper. Anyway, it’s a fairly thick ground knife but I got it push cutting phonebook paper, shaving a little too well and making fairly clean cuts in paper towel. The cuts above the tip in the paper towel are where I stopped.
It definitely worked. I can’t say that I’m surprised because I’ve heard of people stropping on wood. In fact, I’ve heard some people swear by it. Anyway, It would have gone a little faster had I started at coarser grit but I didn’t have any coarser diamond paste. It took a minute to get the feel of it since the wood doesn’t give any. Looking at the edge with my strongest loupe I couldn’t see any discernible remains of a burr but then again I didn’t re-sharpen before the test. I’m not sure if this method is tremendously different than using hard backed leather strops but it certainly is viable. Whether it offers any advantages or disadvantages would take further testing and a level of magnification I don’t have. I doubt the end user would notice any difference in edge performance in the real world.
