- Sep 21, 2013
I popped that 1/8 bar of Aldo's 1080 in and it got non magnetic! So tomorrow I'm off to Costco for some canola oil to give quenching a whirl.
A couple gallons should suffice right? I've read the stickies on 1080 heat treating.
I have a question, however. What do you guys use to hold your quenchant? I see on YouTube Trollsky uses a metal ammo box. Could I use an unused gallon paint can from Menard's or something?
Also for that "FLO" (forge like object) I put the opening for the torch in back, angled towards the front. I think I will flip it around, and the hot spot immediately across from it would hit the tip of the blade. If the opening was towards the front of the Forge I could heat the thicker part of the knife first to not overheat the tip. I could just back a spare brick over the existing hole I would guess?
Can't wait to give it a try.
