- Jun 9, 2011
are they? none left sitting in old stock anywhere? that's too bad. the Japanese version is just a lot better......I think all those on the retail market are from Taiwan.
I have/had lots of Cold Steel and Spyderco knives from Taiwan and their flat or saber grinds have been great.I think the factories in Taiwan can make quality hollow grind knives but have problems with any other grind, even saber grinds.
I'm not sure. think convex, but maybe it's flat. I'm at my other place doing some work today. when I get back tonight I'll take some pics of it for y'all to see what I'm talkin about.....I have/had lots of Cold Steel and Spyderco knives from Taiwan and their flat or saber grinds have been great.
jbmonkey is your Taiwan SM Trailmaster flat or convex ground? Maybe I missed it if you already mentioned it.
Took a quick look, it does look like they tried a convex grind. Wonder if they used humans with slack belts as the Japanese manufacturer used to. If not, it would be the first I’ve heard of automated convexing. If so, that would be the first production convex from Taiwan that I can recall. Thanks for posting.so flatish ground and then to a convex edge....
It seems like what you meant was that you read here that they were over grinding the flats of the 3V Trailmaster and possibly the 3V Laredo and Natchez Bowies. I was talking about their flat/saber folders and other fixed blades. They seem to do most of them well, still.Do you have a 3V Trail Master?
So far from everything I've read there were not just a few with bad grinds, instead no one could find one with a good grind and the consensus was that they were all like that.
Many claimed it was still worth the price but I don't consider a sloppy grind on a $260.00 knife to be something acceptable.
I've heard similar things about the 3V Laredo and Natchez but there is not as much talk about these knives as with the Trail Master.
My saber grinds from Tawain (3V Magnum Tantos) are good, but what I meant was that they might have problems making them since they switched to hollow grinds on the SRK, Recon Tanto, and post-GSM Magnum Tantos.
That San Mai line is very high, toward the spine , compared to what I'm used to .so flatish ground and then to a convex edge....
yeah. that's the not so great part about it. one side isn't too bad. the other is quite high. all the angles coming together at the point isn't all that great either. it's okay and useable as a user, just not as good as the Japanese ones. kinda disappointing. it is cheaper cost wise than the Japan one, and I'm sure others are much better done than this one. so there is a silver lining.That San Mai line is very high, toward the spine , compared to what I'm used to .![]()
My San Mai Japan Trail Master is in a cache , not readily available . But my other San Mai don't have over about 1/4" of the central core exposed .yeah. that's the not so great part about it. one side isn't too bad. the other is quite high. all the angles coming together at the point isn't all that great either. it's okay and useable as a user, just not as good as the Japanese ones. kinda disappointing. it is cheaper cost wise than the Japan one, and I'm sure others are much better done than this one. so there is a silver lining.
You said the Taiwan factories as a whole seem to have trouble with flat and saber grinds, but it’s looking even more like you were talking about 3 knife models in particular.Not just here but in reviews on retail sites.
I've also seen numerous reviews trying to justify the weird grinds as well, but none with examples of grinds appropriate for a $100.00 knife, much less a knife that sells at $260.00 on discount sites.
I don't collect folders.
That’s not how it reads to me, but ok.What I said about saber grinds was not that they can't do them but they for some reason stopped doing them on multiple models.
I remember when the 3V Recon Scouts were on sale there was nothing but praise for their manufacture and performance during use. What happened?
you're not wrong Doc. I'm just don't have the energy to return it and fight for a better one. it was on a sale but not that great of a price. I figure it's now a vg10 fixed blade basically. I'll just treat it as such and sure it will be fine for those uses.My San Mai Japan Trail Master is in a cache , not readily available . But my other San Mai don't have over about 1/4" of the central core exposed .
The only purpose of the harder core is for the cutting edge , so it should best be covered as much as possible , IMO .
Unless I got a very good bargain price , I'd be inclined to return one with too much core exposed .
Edit : Did find this old pic .
