My personal experience actually agrees.I’ve had all 3 and my personal experience is I can get Elmax scary sharp relatively quickly, where as the others take more time. All 3 are great steels, but I prefer elmax
M4Magnacut, Elmax, or M390? Which do you prefer?
Diamond stones are your friend for any of the subject alloys. I sharpen both M390 and 20CV blades on DMT stones and have no problems.I like Magnacut, Elmax and 20CV, but my issue with 20CV is how difficult it is to sharpen. Takes an edge for a while, but it's extremely difficult to sharpen. Magnacut has not been easy to sharpen, and Elmax is clearly the easiest to sharpen "for me."
Different steels require different heat treats. Easily done if you heat treat in batch mode rather than in a continuous production line. You just change the controller. The volumes that Kershaw handles of it's upgraded blade steels could be handled by a large batch kiln.What about Kershaw's heat treat of Magnacut. Take the Bel Air for instance. How do we compare that to Kershaw knives that have 20CV steel for instance like the old Kershaw Links? Does Kershaw have different heat treats for different steels? Thanks in advance!
M4 is good stuff alright.M4
well . . . it has an "M" in it .
+ 1The holy trinity of M4, Cru-Wear and 3V scratch a lot of itches.
MagnaCut has very similar edge retention to Elmax and S45VN but is about twice as tough. M390 has a bit more edge retention and a little less toughness than Elmax and S45VN. Magnacut will be the best for most applications because you can run it much thinner than the others without making it fragile and you won't really be losing out on edge retention.
Elmax is very similar to S45VN, same edge retention but maybe a bit less tough.Where is Elmax ? Always amazed how the Elmax interweb opinions vary / how little data there is. Have yet to chip an Elmax knife. M390 has chipped on me often and it's a PITA to fix. Even S90v which I much prefer for a folder, chips much less in my use.
That is very helpful information. Thank you!Diamond stones are your friend for any of the subject alloys. I sharpen both M390 and 20CV blades on DMT stones and have no problems.
Aluminum oxide does not work as well for alloys containing vanadium carbide. Vanadium carbide is harder than aluminum oxide. So you can crush the chunks of vanadium carbide on an aluminum oxide stone, but you can't shear them. So your edge contains shattered chunks. Using diamond, you can shear them. That gives a much better result.
I have a Kershaw Dividend in Magnacut and the heat treat seems fine to me.
