I’ll try and upload some pics later, but my too are well built, and the axis lock is smooth. The real draw for me was the nice micarta scales, the deep hollow-ground Magnacut blade, and the axis lock. The blade stock is decently thick, but it gets down to a nice thin edge. The ergos are pretty neutral and would likely fit most any hand. Its a great all around knife. Any specific questions, just ask!Any further thoughts and pics would be appreciated. Hard to find much out there from people with that knife
Size matters for utility as well .move past
...basic math and physics, as well as the experience from the entire history of human use of sharp tools /weapons .it came from
My tactical folders fit in so nicely between my martial arts and my firearms…![]()
And , nobody with any common sense has "moved past " the usefulness of a fighting knife as a last resort .
We are badly wandering off topic into Prac/Tac .I get it if people like the tactical aesthetic but the reality is that folders have extremely limited value in both actual tactical operations and real defensive encounters. A big part of that is their level of effectiveness versus alternatives like guns and fixed blades. Setting aside any structural concerns about locks or having a joint, the main reason is just the number of steps and potential failure points between realizing a threat and having the tool ready to use. While some defensive encounters will allow the time and space for that process, lots will not.
This is the same sort of reasoning we see with guns and issues like whether or not to carry with one in the chamber, manual safeties, holster types, etc. Preparing for defensive encounters means betting on potential situations and trying to effectively cover as many of them as possible. Within that spectrum of probability, it's the encounters that happen quickly, by surprise, in situations where you already have a person, animal, or group thereof on top of you, you are already injured, your hands are slippery, you are on the ground, etc. where the extra steps can be a real problem. Given that and that there is an economy of time and action in an encounter, I'd much rather see people working on their empty-handed skills than trusting their defense to a folder as their primary defensive tool.
"Tactical " knives were always primarily used for "support functions " not as weapons .
Except for precise work , almost every other cutting chore is easier, faster and more efficient with a larger blade .
As for Magnacut, I seem to recall that it’s optimized for a fairly high hardness - up around 62+??
If/when I buy a Magnacut knife, I’d want the steel at roughly the optimized hardness, so probably any size folder would be fine but I’d want smaller/thinner in a fixed blade…
I would like to see the basic math and physics calculations you made that brought you to the conclusion that a knife with a thinner geometry would benefit less from a tougher steel than a sharpened prybar that would be near indestructible no matter what steel you used....basic math and physics, as well as the experience from the entire history of human use of sharp tools /weapons .![]()
I think we’d agree that a .22 caliber, two shot derringer also has “extremely limited value” in a fight, yeah? Or how about a tactical pen, or a roll of quarters?I get it if people like the tactical aesthetic but the reality is that folders have extremely limited value in both actual tactical operations and real defensive encounters.
Exactly, that’s why carrying more than one weapon is important.Preparing for defensive encounters means betting on potential situations and trying to effectively cover as many of them as possible.
Just another sign of the collapse/end times .it's not just magnacut. many folders are heavily in the 3.25" blade and shorter length anymore.
No one is disputing that for same BL and OAL .I would like to see the basic math and physics calculations you made that brought you to the conclusion that a knife with a thinner geometry would benefit less from a tougher steel than a sharpened prybar that would be near indestructible no matter what steel you used.
I'll just guarantee you: I can wave any of my 5.5" + blade Cold Steel from either front pocket as fast as I can move my hands from waist high to ready . And I can make my first cut / block on the way .
That cut will just a effective as any from a similar OAL and weight knife . Probably more effective due to fully serrated blades, designed for this purpose .
Allowing your own personal limitations to underestimate others can have serious consequences .![]()
Sure but the point of my original post was that as soon as you start getting into that realm of 0.18"+ thick knives, it hardly matters what steel you use. 1095 is not a particularly tough steel but it gets that reputation because it is almost exclusively used in super thick knives. At the point you're working with damn near quarter inch thick slabs of steel, prioritizing steel toughness over all other attributes its pretty overkill IMO. I don't see what sort of hard use a knife could be going through short of brick chopping that would mess up a 0.2"+ thick knife in any modern steel with a decent heat treatment.No one is disputing that for same BL and OAL .
But overall tiny/thin blade knives are rarely intended for hard use .
Maybe so but it did come up. Given that this is ultimately a safety issue, I feel the same sort of duty on folders as defensive tools as I do in gun talks when people talk about carrying on an empty chamber.
The reasoning I shared against folders for defense applies to most types of folding knife and the overwhelming majority of folders in actual circulation. The Wave feature is interesting in that it was effectively designed as an answer to that. It seeks to hack the process chain central to the reasoning. It might not be a perfect answer, and I don't think it fully closes the gap versus a good defensive fixed blade, but it certainly seems to help.
Matt Conable knife designer, founder of William Henry and Tom Brown, survival expert, would disagree. Conable and Brown collaborated and made the Tracker knife for Brown’s school with a 3” thin san mai hard ZDP189 core blade, button lock folder. Check out Dexter Gordan’s article https://trackertrail.com/publications/inthenews/WHK_Brown.pdfNo one is disputing that for same BL and OAL .
I am greatly comforted !It’s a great knife to take the back out of a chicken.
