Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Can you explain what a chippy, mushy edge is, Nathan. My understanding is that chippy is low toughness and mushy is low strength. When you get both, something has gone wrong in the heat treat.
I also don't understand why you think Vanadis 4 Extra is not tough. What does "durable" mean in a knife steel. Larrin's data show that V4E is pretty darn tough. At 64.5 Rc, he doesn't list a tougher steel. At 58 Rc, V4E is tougher than O1.
And Larrin shows V4E as being tougher than CPM M4. They have about the same toughness when M4 is at 61.2 Rc and V4E is at 63.6 Rc.
Idunno man. I've worked with 4V V4E quite a bit on my path to developing the heat treat and knives that have won the majority of the cutting competitions in the last several years and I have seen a lot of its failure modes but you have a pretty cool chart there and a very strong argument so I expect you probably could make a good sword from 4V. While I probably wouldn't (personally) I think it could be pretty cool and you should try it. I have made some pretty cool competition swords from optimized 3V and it seems like a pretty good material for the application so you might consider that too.
When I say chippy mushy I mean chipping (small areas are missing with limited yielding in the area of the failure) and mushy (denting and edge roll leading to burrs and flat spots without missing bits) which is a very common problem with a lot of knives and "super steels" that have super fantastic cut results in soft abrasive media like rope and card stock but sometimes suck in real life where the edge turns into an accidentally serrated mess when used like a normal person to strip insulation, pry a staple or accidently clack the side of a beer bottle when opening a case of beer. Assuming you drink beer. In bottles. Folks are so used to this they think it's normal.
I tend to agree with you that it is often a problem with the heat treat, but it is very very common and is pretty typical in many, if not most, knives made in certain materials like the high chrome stainless super steels and other complex high alloy steels. 4V is a good example of a material that shows this issue with reduced edge stability when given the heat treat on the data sheet (intended for tool and die) and this is a great example of a material that heat treaters (not just me) have utilized processes very different than the data sheet to achieve the results we want in the thin sections of a knife edge. These tweaks tend to avoid the secondary hardening hump and put a focus on the conversion of retained austenite in the quench rather than after temper to minimize less cohesive mixed structures (RA and the various things it can decompose into) and carbon lean martensite that may work fine in a stamping tool but can play hell in the sections of a knife edge in normal use.
One can have two knives of the same material, same geometry and same rockwell hardness that have very different edge retention properties depending on the heat treat. A knife given a heat treat that works great in tool and die may have a comparatively chippy mushy edge when compared to a knife given a heat treat designed for knives. This is actually pretty common.
I have started using the term "durable" in reference to a knife edge that holds up in rough use. People often say "wow, that's really tough" when in reality it is often anything but tough. A tough alloy and heat treat are often pretty mushy (stabilized retained austenite can be tough) and show a lot of damage in rough use because they're soft (even if just in microscopic areas like the perforations in a postage stamp). Soft is tough, but soft is not durable. We're usually going for a durable edge because (issues with wear resistance aside) durability is the key to good edge retention. It's not a metallurgically correct term but it's a helpful term for the actual property we're discussing because "tough" is often used wrong here and "edge stability" can get you strange looks.
