Magnets+tape+5minutes = TOY
This is a short tutorial on making what I call a magnet flapper or magnet pull toy. It takes about 5 minutes to make, kids can make it with a little supervision. It's interactive and makes a whump-whump-whump sound when pulled apart and a clack-clack-clack when it pulls together.
DON"T LET THE KIDS EAT THE MAGNETS!
Materials Need:
Painters tape or masking tape - to hold the duct tape down so it's easier to work with.
Duct tape - Cheap duct tape is OK for smaller magnets, heavier duct tape is need for magnets above .5 inch in diameter, if you're using magnets over 5/8 diameter you'll need to use Gorilla duct tape. A special note here that cloth faced tape will seal to itself when you use larger magnets and will be impossible to pull apart. The magnets will squeeze the adhesive through the cloth face and it will be a solid stack of magnet and tape. Cloth faced tape works up to about 1/2 inch diameter magnets. Anything larger needs a vinyl or other tape face. Nashua has several tapes with a smooth face. Gorrilla tape also has a smooth face.
Disc rare earth magnets - In this I use 3/8 inch diameter by 1/8 thick disk magnets. I do not reccomend you buy anything thinner then 3mm or 1/8 inch. Thinner magnets will break very easily and will shatter and will cut you. Also for this toy anything over 3/16 thickness will make the tape bunch up and not look very pretty.
You may be able to find rare earth magnets at your local hardware store but they will be more expensive. If you plan on making many, it's cheaper to buy online. I usually buy magnets from www.kjmagnetics.com. You can look in the discount or clearance sections to get better deals.
3/8 diameter rare earth magnets are good as even kids can pull them apart, yet they're strong enough to be cool. 1/2 to 5/8 inch in diameter is cooler yet but more expensive and slightly more trickier to make. I've made ones with magnets up to 1 inch in diameter and they little beasts. Ceramic magnets won't work very well, I tried them, they too big and too little power. Rare earth magnets can vary in grade from N35 to N50. Anything N35 and above work fine as the grade go up they get more expensive. You can buy ebay but the vendors range from good to sleazy.
To get started I put a piece of cardboard down so I don't get the table sticky. Here you can see the stuff I have laid out. I'm going to use Permacell cloth faced tape for this example. I have a previous toy I made in yellow.
Here's a close up of a stack of 3/8 magnets and the previously made toy.
You can see I took a strip of duct tape sticky side up, and used painter's tape on the edges to keep it from moving around. You can also see I have started placing the magnets. When you're making this toy you need to alternate poles. The easiest way to do that and keep track as you go along is mark one end of the stack with an X and the other end of the stack with a O. Everytime you remove a magnet from the stack, make the same mark on the very next one on the stack. Once you have placed and remarked the X, then flip the stack over and put the next O magnet. Remarked, flip, place etc. until you have run out of magnets or space. Make sure you press firmly so the magnet will stay anchored to the tape!
So now I have worked my way all the way across the tape. The distance between can be about 3/4 of an inch. If you are using bigger magnets increase the spacing between them. A word of caution, especially with bigger magnets. Keep the stack away from the magnets on the tape. Otherwise the tape will pull up or the stack slip out of your hand and make a big messy magnet tape mess. I don't go all the way to the end, I leave a little bit so I can attach the finger loops.
When you have gone all the way across, take another piece of tape, sticky side down, and put it down on top. Use a marker to something to firmly push down the tape and work the tape in around the edges of the magnets.
Carefully pull up from the surface and tear off the painters tape. Working methodically from one end to the next, fold the tape alternately so the faces of the magnets attract each other. It should look like an accordian when done. Once it is folded up, crease each fold of the tape between your fingers. This gives the tape some "memory" effect and will guide the magnets together when released after pulled apart.
Trim and clean up the ends with a scissor. To make the finger loops for the end take a half with of tape, sticky side up. Then overlay with another shorter strip, leaving about 3/4 inch of sticky remaining on each end. Loop the sticky section over each end and press firmly so it stays bonded to the magnet strip.
Here's what it look like pulled apart. To use stick a finger from each hand in the loops and pull apart. Then as you bring your hands together it goes clack-clack-clack... as it pulls together. If it doesn't fold together in order smoothly then fold it yourself and re-crease the tape. If it still doesn't work then it likely needs remade with closer magnet spacing.
Here's an example of magnets that are too strong for the tape.
They are 5/8 diameter disks and the tape is cheap tape. The result
is that the magnets have shifted within the tape from the force required
to separate the disks when playing with the toy. In this case I should have
used a heavier tape.
Should this happen and you need to take one of these apart, carefully score across the top of the magnet face through the tape with a knife. Then peel the tape away and remove the magnet. Repeat with other magnets. Be careful with larger magnets as they will grab and hold the knife.
if my parents gave me this toy, i would knock it to the ground and then turn my attention back to my playstation 3 for the rest of the day.
love isn't made on your kitchen table with your spyderco and leftover painters tape. it's bought. in japan.
;) :D
;) :D
Bah. When I was a kid, i played with DIRT, and I was THANKFUL TO HAVE IT! Each year for Christmas, I got socks and blocks. Hours of entertainment! Durned youngsters and yer morally bankrupt hip-hop culture. . .
Please use this under heavy supervision. This would NEVER be allowed to be sold in the USA as a safe toy for children. If two strong magnets got loose and were swallowed by a young child, they could pinch an internal organ and cause very serious injury.
Dear Grouch, you are absolutely right. I guess most parents can't be bothered to keep an eye on their children or teach them not to eat stuff. Geeze I even put a warning at the top did ya miss it?
While I saw your warning, the repeating Chinese manufactured toy events reveal how lax many parents are with supervising.
Another fun thing to do with small magnets is to hang one from the ceiling by a string or thread so that it hangs maybe six inches off the floor. Now array three to six more magnets in any sort of pattern within about a two or three foot radius of the where the first hangs. Pull the first back and let it swing as if a pendulum. But it will not swing like a pendulum back and forth. It will swing eradically as if it has a mind of its own as it interacts with the magnetic fields of the other magnets. Mathematically, predicting its course is so complex that it is actually impossible. Something so simple as a few magnets and a piece of string and yet it defies analysis by even the most powerful computers.
The Barbie dolls with the small magnets to hold their cloths on which have recently been recalled because of the danger of swallowing small magnets -- especially the very powerful magnets we have today -- were made in China, true. But they were designed in America.
It's very true that loose rare earth magnets must be kept away from babies, and this toy could revert back to loose magnets.
I think my nephew would enjoy making it and playing with it, and he's 10 years old and doesn't put everything in his mouth any more, so I'm going to see if I can find some suitable magnets before I see him on Thanksgiving.
lee valley, the spherical rare-earth magnets they have are hours of fun watching them roll seemingly randomly around attracted by the nails in the floor. Bring on the Dangerous toys, maybe if people thought about risk management for themselves we would all be safer. (rant from a professional kids camp leader/ addict I shouldn't be the one raising other peoples kids to think)
;) :D
At least good stuff comes out japan theses days.
:thumbup: When I was a kid, which wasn't exactly the dark ages, my friends and I had all kinds of cool stuff that did not require a TV or computer monitor. Chemistry sets, stuff with electric motors, BB guns and .22 rifles, pocket knives, bicycles (in those deadly pre-helmet days), etc. Somehow we all survived childhood and, hard as it may be to believe, we learned a thing or two other than which thumb controls the trigger.
of course those "toys" only got played with when there were adults around for the most part, or there was going to be someone to run home for mom. maybe that's it, my parents did a lot more than make sure that there was food in the fridge. funny that now I've moved out I realize that they did know what they were talking about. either way, I'm safer because I know my toys can bite me.
I was happy with a stick and a rock.
;) :D
If my child knocked a gift out of my hand, he'd be turning his attention to his backside.
Then he'd watch as I gave his Playstation to Goodwill. :D :p
My "skateboard" was an old metal skate popped in half and nailed to a 2x4.
We got four channels on a B&W television, only one of which came in clearly.
I played with sticks a lot. A magnet would have been a treat.
Somehow, I survived.
My kids liked playing with some 3/4" PVC pipe. I cut it into 6", 12", 24" and 36" pieces. Add a couple of bags of assorted elbows, tees, and connectors. Cheap and fun.
The pipe also fits in the vacuum cleaner so it occasionally gets used for those hard to reach places and occasional bug.
Ric
Pretty upscale life - you got dirt, all I got was the box it came in.
As for being old, my toys were made of wood, and used stains and paints now considered hazmat. The metal ones were a collection of sharp folded edges sharper than the knives I wasn't allowed to have.
We used to hunt smaller reptiles with the unfolded tail fin of a Japanese toy plane - I think we caused major extinction of species, but who knew, there was only one TV channel we couldn't get, and no internet.
We'd sit in front of the TV for an hour on Saturday and watch for ghosts or cartoons to appear. "They're baack!"
I think they captured the last generation.
