Major Score - Is it what i think it is
well today i got the idea to head up the the my famus surplus store that you guys know about ;) and after a few min i picked up this great find. In the metal section i spied 2 coils of what appeared to be sheet metal but then i caught the glint of a blue sheen. I ran over and grabbed both and realized thy where quite heavy, each one is over 60 pounds in weight. so i have around 120 pounds of spring steel in these 2 coils. i noticed that on the inside it says .006 thick and over 4" wide. i tried to bend over a corner and to my delight it sprung right back straight. so i am guessing its ether 1075 or more likely 1095 with a blue temper, and being .006 means a lot of Damascus for me. does any one have any connections that could test a bit of this so i could know for sure what it it. the next score was a box of 1/4" coarse sanding drums. these are the kind you use on a dremel tool. the label on the box says there is 10,000 in there :eek:. These sell online for about $11-$12 bucks for 100 so i would say i walked away with a really good find. And i only payed 58 bucks for everything.
Man, nice score! What would make it even better is if that steel is what you are looking for.
If you send me a 1" square piece, I *might* be able to get our test lab to determine its composition. No guarantees.
Al
Seriously man, you gotta share the identity of this secret store... I'll be in Provo in June and would love to pick up some contact wheels and maybe a motor... *hint* *hint*
Contrary to the seemingly good idea, a small stack of thin sheets is much harder to weld up into a damascus billet than a big stack of thick bars. Ten 1/4" bars and two folds will weld many times easier than forty thin strips once.It will also make ten times the amount of damascus. I know that you can do the math, but 40 layers of those sheets is only 1/4".
Stacy with the reality check.
Sadly, Stacy's right. On the plus side, I'm sure you can figure out something to do with all of that spring tempered shim stock
Page
