- Jan 24, 2011
The easy way.
First get one of these at Wally. The rubber pad is just like a mouse pad. The paper clamps to it tightly and you can hold it in your hand, convex your knife and watch TV. This makes the hours and thousands of strokes it takes go by easier.
I like tip to heel, but the opposite works too. Whatever is most comfy for you. The MAIN thing is to not put downward pressure on the knife. I know you want to speed up the process, but to be successful, light pressure (just the weight of the blade) works best.
and the other side, very very light downward pressure..
Starting with a V grind, get your profile with coarse paper. Start with 100 or even 80 grit to remove the amount of metal that you need to. Then refine the edge by going upward through the grits all the way to 2000. Then strop with leather and green compound. Take your time with each grit and don't expect to get there quickly. It takes patience but you WILL get there. This is why I suggest the hand sander.
