First, welcome to Bladeforums. I must say you have been around reading a long time before your first post.
Second, filling in your profile will help a lot. Some basic info about you, and where you are can often get a near-by smith to offer help.
It really helps when the question answer depends on your skill level and such. For instance, a question on building a grinder will get a different answer if you are a 16 year old student with no tools that if you were a 40 year old machinist with a full shop.
When asking a question, the more info you give, including photos whenever possible - the better answer we can return.
Questions about a knife build should give size, blade steel, blade shape, how you plan on making and heat treating it, and if possible - a sketch.
Now, about your planned grinder build.
The motor and controller may or may not be useful - The motor and controller are two of the more expensive items on a grinder, so you were smart to think of them first.
The wheel almost surely won't be the right type for a grinder.
Rebuilding a pitching machine into a grinder may be far harder and expensive than building a "Grinder in a Box" or similar grinder kit.
Let us know the HP, speed, frame type, and motor class that the motor plate gives ( a clear photo of the motor and one of the plate would be best). Also tell/show us the speed control type.
Welcome, again.
