Nathan, I was fishing for information to try and ask proper questions and narrow in on things. Simple to more complex.
snip
I had no good way to ask questions about pitches and minor diameters.
I don't disagree with anything you're saying. But I'm not sure you understand where I was headed with my questions. There was a method to my madness.
Ah, I see your point. Sorry if I was being obstinate...
Dan Gray wrote:
"Nathan not to get down on you but when you say
'Moly-dee from Castrol is the best" are you saying it's the best you've tried??
to me to say that it's kind of like saying that 5160 is the best steel for all knives.."
Dan,
5160!? Nope, D2! (oop, there I go...)
While I was in my early 20s I had the good fortune to work as a hack machinist while I was going to school. I had to make a large production automated drill fixture (over ten feet long and half a ton) with many many holes to be hand threaded. Any broken taps in the main fixture was a real problem to deal with. Having used "tap majic" and others and still suffering problems I sought out a very experienced machinist from a different shop who said moly dee was the best he had used.
Since then I have heard similar stories which reinforced my POV. Is it the best in all circumstances? It is relatively expensive, stinky, black and messy and hard to remove from the part. So in a production setting it is certainly not the best choice. But in my experience, when threading a part where you really really don't want a tap failure, it is the best I have been able to find. I have never had a tap fail due to galling while using it.
If a new impressionable new guy reads this and uses it on his knives, I can say, speaking from experience, it will work well, and probably work better than other common tapping oils and pastes that I have tried.
Obviously, I shouldn't have said "the best", because I haven't used everything out there, and currently do relatively little hand threading anymore. But it is in my opinion, and in the opinion of a couple shop owners and other experienced machinists that I have talked to about it.
But I'm being long winded... Your point is taken.
