Hey guys,
I'm looking to make my dream machete/ hybrid chopper that will be ideal for everything from clearing brush to chopping down an oak tree. I am thinking the blade will be around 15 inches and will be about 2.4 inches at the widest, tapering quite a bit towards the handle for alot of forward weight. Thickness wise I am probably going to go on the fat side with .187-.150. The knife will most likely have a high saber grind.
What steel would you recommend for this blade? I want very high toughness and flexibility and will have the blade professionally HT, most likely with a differential temper. Right now Im looking at 5160, 52100, and 1084 and leaning towards 52100 because of its edge holding. All are pretty inexpensive and seem to have excellent properties that would lend to a chopper/machete. Is there a significant difference in grindability between the steels? Also which steel will be the least likely to warp? Are there other steels that would be better suited for the blade in mind?
Also what are some tips for grinding such a big piece of metal? I use a 2/42 craftsman and I also have a 4X36 inch sander than could be used for shaping.
Thanks in advance!
Thanks in advance!
