- Aug 28, 2010
Thanks for the photos, I'm now inspired to make my own broad axe handle from a big old oak branch..
The ability to work outside without losing any fingers or toes would be pretty nice too. Im happy when the temp gets to zero (chuckle).. makes it feel balmy
I have to give you an advice: Use wooden wedges instead of the iron ones. Get on the top of the haft a crosscut and add there the wedges. Imo this works much better than any iron ones. May hafts are of ashwood, so the wedges are also made of ash.
Kind regards
Andi
I would rough the half out, put sealent on the ends and put it some place to dry out. If you don't have a moisture meter just weigh it once in awhile untill it stops loosing weight (i.e. water).
Yeah, I have too much crap in the garage to work in there but at least I have a covered patio to work under. Typical winter day down here is 40°F and drizzling. All you need to work outdoors is a light jacket and a roof.
Thanks, Andi. I'll probably make my wedge out of some of this Oak or else some dry London Plane I have on hand. The London Plane is even harder than the oak with a coarse gritty grain. I think it'll make a nice wedge.
That's looking great. Don't know if you considered it, but FWIW here's my two cents. I would rough the half out, put sealent on the ends and put it some place to dry out. If you don't have a moisture meter just weigh it once in awhile untill it stops loosing weight (i.e. water).
Anyway, thanks for posting. Someday I want to make one like yours.
Not a bad idea. I wonder if I'll have difficulty working with that second half of my branch after it's been dried. My gut tells me that I'll be using sanders more than rasps to shape the dry one. OTOH a dry piece might be more dimensionally stable and less apt to twist after being shaped.
Gets HOT and dry in there. My dad mills his own boards and dries them up in the crawl space.
As I understand it, the stress is still in the wood after it dries. When you work stress wood you reduce the mass and allow the stress to exert itself. My only point is that stress wood is not predictable. Not that any piece of wood is, but limbs are highly unlikely to produce dimensional stability.
Interesting!
I'm taking a crooked piece of wood and hoping it stays a crooked piece of wood.
