- Nov 9, 2006
Since Eric Fleming showed his build of a ribbon burner table forge, http://www.bladeforums.com/threads/table-forge-with-ribbon-burner.934512/ I've had it in the back of my mind to build one myself.
Finally getting around to the build, I tried to make a half-cylinder cover for it like he did using kaowool and satanite as a rigidizer. Unfortunately, mine collapsed while I was trying to dry the outer shell so I'm back to square one. I build a form for the kaowool and did the inside of the half-cylinder, drying the kaowool with a heat lamp overnight. Got three coats and about 3/16" thick coating of satanite. I then carefully turned the kaowool out of the form using soft firebrick to support the top of the dome while I fired the forge for a while to bake it. When I started to paint the outside of the kaowool, everything came apart from the weight.
Has anyone made a half-cylinder or dome cover for a forge? Any suggestions for attempt number two? I was thinking of making a metal shell and lining it with kaowool, but not sure how well it would stick and stay in place. Fasteners won't work because they'd just conduct heat to the shell.
I'm open to any and all suggestions. FWIW, I really like the flame shape and concept of the ribbon burner and it was cranking well on 2psi propane.
