Making a folding knife (sanmai and buffalo)
Hello, i want to show you how i make a folding knife, the blade is a 1095 sanmai, and the handle is made from a buffalo horn. Excuse me about my poor english.
Materials:
- 1010 rectangular profile:
- Two strips of 304 inox steel:
- Two SAE 1020 strips (4 mm thickness)
- Two nickel strips (1 mm):
- One 1095 steel plate for the center:
I clean all the surfaces, except the exterior sides:
I dispose the pieces (304-1020-nickel-1095-nickel-1020-304). The 304 is in order to the pan don´t solder to the tube.
Closing the tube:
Introduct the pan in the tube:
Fill the rest with steel wool:
Handle soldered:
20 minutes in the forge:
And when it´s hot...
I press it at about 1.200 ºC:
I open the capsule:
I grind until obtain a lingot:
And i reveal with ferric chloride to see the contrast:
I stretch the lingot:
I grind the contour:
I cut it into this form:
I reveal again in order to not lose the center:
I make cuts and holes for draw the line:
I make a small bevel to mantain the 1095 in the center while forging:
And i forge the blade. First the back zone:
Then the point:
And then the edge:
I reveal again:
Rectify the sides:
And make the bevel:
Reveal (again):
Now i make the heat treating. I put in it soldering spray in order to avoid decarburization:
Two normalizing cycles:
Quench in oil:
Temper:
I finish the machine grinding:
I decide that i will make a buffalo horn one-piece handle:
Now i make the ring:
Now i make the spring. I start with a 1070 strip:
I forge it:
I heat treat it:
Temper into 400 ºC.
I make a hollow in the horn:
I make the finishing of the ring ang glue it:
Once it dries, i polish:
I nail the spring to the handle:
I electro-engrave my logo:
I cut the nail and made the lock groove:
Then i polish the blade:
I make the lever:
I make PET rings:
I polish the conjunct:
400 grit:
600 grit:
Definitive revealing:
Hammer the blade to the handle:
Wow. Love the details and pictures you included.
Perhaps it's just me, but I would be very frightened to quench in a plastic tub though.
It's not just you.
I once used a plastic pail inside a metal tub.
I melted a hold in the pail.
Thankfully I had the safety tub and the oil didn't run all over the floor or catch on fire.
It's not just you.
I´m thinking about it. Probably you´re right. I will not quench in the plastic recipient, i promise you.
However, it was a small blade into 3 gallons of oil.
That was awesome! At first I wasn't too sure what to expect, but the final knife is stellar! I am not one for folders at all, but that is beautiful!
Gracias por compartir, hermano!
